Old 01-17-2018, 06:02 PM   #1
moogoogypan
moogoogypan has a spectacular aura aboutmoogoogypan has a spectacular aura aboutmoogoogypan has a spectacular aura about
Default not good
Just replaced the timing chain tensioner on my 2.2l Vue with the new style tensioner as described in this thread.
http://www.saturnfans.com/forums/sho...d.php?t=164332
Well, started it up and seemed to idle fine but justas I touched the peddle the car just died.
Have i managed to destroy my engine due to the tensioner not activating leading to the chain jumping the sprocket?
Any advise on moving forward. How do I confirm my suspicion?
Add to moogoogypan's Reputation
Rate the quality of this post and help moogoogypan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
moogoogypan is offline   Reply With Quote
Old 01-21-2018, 07:44 PM   #2
moogoogypan
Default Re: not good
Removed valve cover. Chain had skipped one link. Reset chain. Engine sort of almost would run. Conclusion: bent valve(s)
Realize now I could have activated the tensioner by removing valve cover alone. Live and learn.
Old 01-22-2018, 04:57 AM   #3
guyg
guyg will become famous soon enough
1997 SW2
Kind of doubt one tooth would cause damage, a compression test would verify.
Add to guyg's Reputation
Rate the quality of this post and help guyg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guyg is offline   Reply With Quote
One headlight out on Ion, both fuses good. Bulbs good. SL2 Ride Ion Tech 4 07-05-2017 05:48 PM
no back up lights... good fuse, b/u switch, bulbs, good ground... going crazy! DJboozeAlot S-Series Tech 8 02-19-2010 08:23 PM
Good article on why it is NOT GOOD to use stop leak products..and other car info 2NDSOUT S-Series Tech 7 06-16-2009 05:39 PM
Whats makes good tires good? carl S-Series General 1 07-10-2006 02:28 PM
