Old 01-17-2018, 01:42 PM   #1
kohly
kohly is on a distinguished road
2004 ION-1 Sedan
Default Clicking when starting
hi ive got a 2004 saturn ion 1. ive had intermittent trouble with clicking when starting with full power. i recently purchased a new battery and an ignition switch,as ive heard this is a common problem. well after i replaced the battery and ignition switch the clicking when starting occurs everytime when the weather is cold and will not start but when i hook up my battery charger and set it to quick start the car starts immediately and when it gets warm in the vehicle the car will start no problem but once it gets cold from sitting overnight the vehicle returns to clicking. im at wits end is there a solution to this or a bypass to this issue? Any help would be greatly appreciated. i live in iowa so id like to solve this problem thank you
Add to kohly's Reputation
Rate the quality of this post and help kohly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kohly is offline   Reply With Quote
Old 01-17-2018, 02:06 PM   #2
Default Re: Clicking when starting
There may be several issues to address before getting to an answer. A trunk mounted battery may present battery power issues with longer power cable than normal (red). Be sure battery positive and negative cables are clean and free of corrosion. Battery negative counts on several ground connections to connect battery negative to the engine and chassis. On the engine bay, battery positive (red) is connected to the Remote Start Terminal next to the engine fuse panel with a long post to allow connecting a jumper cable for jump starting. Check this stud for looseness as this battery cable connection feeds power to the main fuse panel and another cable goes to the starter. One member found this stud loose and the source of starting/power problems.
Another area of concern is car mileage. What's mileage as this may have some bearing on whether or not the starter is worn out. A simple starter test requiring crawling under the car and sorting out two terminals on the starter can help determine if the starter is worn out compared to starting circuit problems.
Old 01-17-2018, 02:26 PM   #3
kohly
2004 ION-1 Sedan
ive checked the jumper post under the hood and that is tight and also cleaned the battery posts and wire brushed them. should i change the starter as a next step?
Old 01-17-2018, 02:57 PM   #4
I'm hesitant for the following suggestion because of your situation requiring testing the starter on the same conditions you described and in cold temps. To isolate a starter problem (worn out after years or reliable use) can be done in several ways but results are the same; using any screwdriver to act as a switch, shorting the large terminal with battery cable on the starter and smaller terminal on the starter bypasses all circuitry and simply applies battery power to the starter solenoid to power it up. This requires jacking the car up to crawl under it, ensuring ignition is off, parking brake applied and shifter in Park position. If hesitant, wiring a (momentary) remote starter switch with two alligator clips to connect to the starter terminals also works and keeps you safely away from under the car when testing the starter. The starter should power up immediately and turn over the engine. This presumes battery and connections are good. Good starters will power up immediately while worn ones may or click repeatedly or do nothing.
Old 01-26-2018, 05:34 PM   #5
kohly
2004 ION-1 Sedan
today it was 48 degrees out and it still clicked so im leaning towards the starter so that will be my next purchase if it aint that its going to the crusher
Clicking noise when starting up then... ngrome S-Series Tech 4 04-30-2015 09:45 PM
Clicking while starting Sir_Brizz S-Series Tech 5 02-17-2011 08:41 AM
My 97 SC-2 not starting. No cranking, no clicking no nothing Harold97 S-Series Tech 15 01-28-2011 12:09 AM
Clicking noise when starting HotCookCpl S-Series Tech 4 02-29-2008 11:41 AM
94 SC2 Not Starting, No Clicking, New Battery edbama2 S-Series Tech 1 08-24-2005 10:41 AM
