Old 01-14-2018, 09:06 PM   #1
flagtie
flagtie is on a distinguished road
Default What is this? How about that? (Pictures)
So I replaced the clutch hydraulics on my 95 SL2. While in there I found a tube with a cap (pressure relief maybe) on a stud above the coil packs. The other end is not connected to anything.
Then I also found a fitting (on top of the shifter box maybe) It also is connected to nothing.
Yes I figured the hose probably belonged on the fitting but it definitely will not reach from where the tube is mounted. Maybe the tube is mounted in the wrong spot.
Ideas?
2002 Saturn SC2
1995 Saturn SL2 with Trailer Hitch
1983 Porsche 944
1981 Camaro Z28 4 Speed w T-Tops
Add to flagtie's Reputation
Rate the quality of this post and help flagtie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flagtie is offline   Reply With Quote
Old 01-14-2018, 09:42 PM   #2
Waiex191
Waiex191's Avatar
Default Re: What is this? How about that? (Pictures)
That is where it went - it is a gearbox vent. Maybe the hose rotted and broke. I'll see if I have any pictures.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-14-2018, 10:02 PM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
You do realize you posted a picture of a nipple?
I had that hose break off too and I kicked myself for not being more observant.
When I discovered the broken hose, I replaced the transmission fluid.
You see, there is no real filter in the manual transmission and some gritty dust could get sucked/fall into the transmission. Not good for the needle bearings.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 01-16-2018, 09:59 PM   #4
flagtie
OK. Good stuff. I'll move that tube to somewhere it reaches the fitting and re-attach all.
Thank for the help.
2002 Saturn SC2
1983 Porsche 944
"Reverse Slam" repair part pictures+repair pictures. CaptainMouse64 S-Series Tech 44 04-08-2009 06:40 AM
Nav Pictures..could you please take some? hortaja Outlook General 0 01-04-2007 08:51 PM
Some Pictures Low Saturn General Saturn Discussion 18 02-15-2005 01:44 PM
ION 3 SE Pictures OhioVueBoy Ion General 37 09-10-2003 05:15 PM
New pictures of my 99 SL2 jegster S-Series General 2 08-11-2003 11:27 AM
