Old 01-12-2018, 08:47 PM   #1
Bluplastik
Bluplastik is on a distinguished road
1995 SC1
Default dis/reconnected battery, now car running smoother?
I disconnected the battery on my "new" 95 SC1 for a while while I cleaned and acid neutralized the tray and surrounding area. Since reconnecting the battery the car seems to be running smoother both at idle and highway speeds. Is that possible? The SES light (code 32) went out and stayed out afterwards too. I opened the hood intending to clean the EGR valve when I got sidetracked 😄.
1995 SC1 76000 miles
2005 x-type sportwagon 56000 miles
Add to Bluplastik's Reputation
Rate the quality of this post and help Bluplastik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bluplastik is offline   Reply With Quote
Old 01-12-2018, 10:34 PM   #2
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Default Re: dis/reconnected battery, now car running smoother?
My guess is that when the EGR code 32 disappeared then so did your engine issues. Unless your battery connections were corroded or loose, the battery would have no effect except on starting performance.
Old 01-13-2018, 10:04 AM   #3
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Reconnecting the battery will have forced a EGR position relearn.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
94' SL1 running off battery.. EFG S-Series Tech 5 10-24-2011 10:03 PM
Starter moter just running when battery is connected.. captngrif S-Series Tech 6 04-16-2009 03:20 PM
new SL2 owner ('99) should it be running smoother? ziprhead S-Series Tech 5 01-30-2008 08:52 PM
Battery light, but car's running fine! callmethewander S-Series Tech 9 06-17-2005 07:04 AM
L200: Running wiring from battery to trunk knakonec L-Series Tech 0 04-11-2005 02:19 PM
