Old 01-11-2018, 06:23 PM   #1
orest402
orest402 is on a distinguished road
2008 VUE 2.4L
Default 2008 Vue headlamp adjustment screws location
Hello everyone. Today I changed out my driver side headlamp bulb and after replacing them I wondered where the adjustment screw was on the unit. Is it necessary to remove the unit or can it be adjusted externally while in place. I looked and looked and can't seem to locate anything that would be an adjuster. Anyone know where I should look to try and aim "down" the light a bit? Thank you for any help you can offer.
Add to orest402's Reputation
Rate the quality of this post and help orest402 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
orest402 is offline   Reply With Quote
Old 01-11-2018, 08:01 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2008 Vue headlamp adjustment screws location
The vertical adjustment screws are hidden in a hole in the radiator support on each side. There is no horizontal adjustment. I'm not sure what tool is required to turn it. I found two manual excerpts with conflicting information. One says an E8 Torx socket is required, but another one says a regular 6mm hex socket is needed.
2007 Ion 2 Quad Coupe 5-speed manual 179K miles
2007 Chevy Equinox LT 190K miles
Add to ruley73's Reputation
Old 01-12-2018, 12:51 AM   #3
orest402
2008 VUE 2.4L
Thanks for the helpful reply....I did note the hole at the top of the front radiator support and will have to shine a light down there to find the adjusting screw. Makes sense now
Old 01-13-2018, 11:36 AM   #4
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
I'm pretty sure it's the 6mm hex socket. At least, that's the same one they used on that year model Relay.
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
Old 01-13-2018, 07:20 PM   #5
orest402
2008 VUE 2.4L
Thanks guys for all the helpful replies to my inquiry. I'll have to give the headlamps a "tune-up" adjustment. Tired of looking up at the trees while driving at night on the passenger side......
2008 Headlamp Removal TDragon 2008 Vue 6 08-19-2013 05:29 PM
Headlamp adjustment issues CM400T S-Series General 5 04-13-2013 01:44 AM
Snapped the headlight adjustment screws... Derek McNelly S-Series Tech 2 04-22-2010 07:32 PM
Headlamp Horizontal Adjustment marx404 Astra Tech 8 12-28-2008 11:27 AM
2004 ION Quad Coupe - Headlamp Relay Location? boothpl Ion Tech 3 05-02-2008 04:07 PM
