Old 01-03-2018, 02:10 PM   #1
510man
510man is a jewel in the rough510man is a jewel in the rough510man is a jewel in the rough510man is a jewel in the rough
Default Installing 1996 DOHC in a 2000 SC2
I have a 2000 SC2 that has no compression in #2. I found a rebuilt '96 engine for a good price. I know the engines are different. What's different and can I install the '96 in the 2000 car by swapping a manifold, etc?
For example, I believe the intakes are different. One metal and one plastic. One sidedraft throttle body and one downdraft. Will the sensors and connectors on the plastic downdraft (what I have on the 2000) connect to the metal sidedraft (what I believe is on the 1996)? The air filter box would need to change too.
What other things are different and will they move over? Open to hear thoughts on whether this is worth doing.
Add to 510man's Reputation
Rate the quality of this post and help 510man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
510man is offline   Reply With Quote
Old 01-03-2018, 03:10 PM   #2
Default Re: Installing 1996 DOHC in a 2000 SC2
No experience, but I think you want to keep everything from the '96, including intake and exhaust manifolds (and maybe downpipe).
You want to use the injectors and fuel rail from the '00 though, I believe
Probably should wait until someone with experience chimes in
Old 01-03-2018, 03:18 PM   #3
This question has been answered in detail, use the large search box. Search "engine swap" and then look at the various posts titles to see how to narrow it down.
Keep the 96 exhaust all the way to the back of the cat. Use the TPS from the 00 as the connector is different and probably the knock sensor. The rest drops in. Intake piping from the 96. All of the other electronics and injectors will be OK unless the 00 has the long skinny injectors and then it is best to either buy the connector adapters or cut and splice so you can say with the old style injectors. Your big issue is the 96 has the regulator on the rail and the 00 does not. A 98 fuel rail is the easy fix for this as it is also a returnless fuel system.
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 06:48 PM
Installing Temperature Guage coolant sensor in 1996 head PlasticFan S-Series Mods 6 06-08-2008 10:57 PM
Will an 1996 or newer DOhc engine fit in a 95 SC2(dohc)? e dogg S-Series Tech 4 04-04-2008 11:14 PM
Swap 2000 SL2 DOHC (auto) into a 1999 DOHC (manual)? kim_lombard S-Series Tech 3 02-22-2008 12:12 AM
99 dohc engine oil priming before installing saturnben S-Series Tech 4 11-20-2007 01:10 PM
