Old 01-02-2018, 01:46 PM   #1
Jcolson10210
Jcolson10210 is on a distinguished road
Default 1994 sl1 5 speed STUCK IN REVERSE :(
So, I went for a short drive(about a mile round trip) last night without letting my car warm up (i was in a hurry) temps were in the single digit negatives. Got back to my house and parked I put it in reverse backed up into my spot went to take it out of reverse and its stuck in reverse. The shifter moves back and forth not really much side to side but doesn't come out of reverse. Any suggestions?
Add to Jcolson10210's Reputation
Rate the quality of this post and help Jcolson10210 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jcolson10210 is offline   Reply With Quote
Old 01-02-2018, 02:02 PM   #2
Waiex191
Waiex191's Avatar
Default Re: 1994 sl1 5 speed STUCK IN REVERSE :(
I'd suggest looking at the shifter cable. Both at the shifter and on the transmission. The cable end probably fell off or busted.
Edit:
https://m.ebay.com/sch/i.html?isRefi...=1&_mwBanner=1
http://saturnshifterbushing.blogspot.com/?m=1
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-02-2018, 02:30 PM   #3
Do not try forcing it as things bend or break. Inspect carefully and report what you find. This is not hard to fix no matter what fell apart as long as it has not been forced.
Old 01-02-2018, 03:03 PM   #4
Jcolson10210
This is the culprit. Thank you! What would be the best fix? Should I replace anything else while I'm replacing this?
Edit: The photo isn't posting
Old 01-02-2018, 03:08 PM   #5
Jcolson10210
Old 01-02-2018, 03:12 PM   #6
Jcolson10210
ibb.co/mBVsWb
Here is a link without the https://
Old 01-02-2018, 03:23 PM   #7
Immediate fix is a couple tie wraps to hold the link on the ball. Then you replace the bushing with a permanent fix.
The plastic or steel one works. This is the only approved seller so you can find copies but good luck with the quality. https://www.ebay.com/sch/saturnbushi...88.m1543.l2654 I would recommend the steel bushing replacement but it MUST be installed correctly per the instructions.
Old 01-02-2018, 06:47 PM   #8
Signmaster
Temporary fix option
As you can see, this "temporary" fix has held up quite well. I got the delrin bushing, but this is on so snug it's not worth destroying to put the other on. It's just an option, and I always saw it mentioned as temporary.
I didn't like the idea of zip ties or anything that would abuse the loop end any more than needed. I did slightly trim the bushing so it fit all the way on the ball better, but other than that just popped it on.
Don't abuse the cable end, as the same seller that sells the bushings sells the cable end fixes for a reason.
Old 01-05-2018, 12:34 PM   #9
2NDSOUT
2NDSOUT's Avatar
1999 SL
Your Shifter Bushing is broken. From your picture- done and repaired this so many times; more then I can think.
The link that OldNuc points to- is the way to go.
Jerry Borschard (Saturn Bushing Man) was on this very forum many years ago and designed the replacements. I have used both in my cars over the years. I went with the Stainless Bushing replacement and even went a step further with JB Weld and the E-Clip. As a side note, be very careful with the E-Clip replacement. Harbor Freight sells an E-Clip assortment; if by chance, your replacement E-Clip flings off when you are replacing it with a pair of pliers... been there done that.
This is a fairly easy repair, but seriously- take your time when making this repair work.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Stall when put in reverse DTC 26 TCC Stuck tomb S-Series Tech 2 12-02-2010 10:24 PM
Car stuck in reverse...HELP!!! peteygnyc L-Series Tech 1 07-10-2010 11:58 AM
2000 LW1 stuck in reverse cadurning L-Series Tech 8 10-30-2008 07:09 PM
What would cause my shifter to get stuck when I reverse? turbobuick33 S-Series Tech 6 06-18-2008 10:29 AM
Key recalls? 1994 & 02 keys stuck goldnugget Vue Tech 1 04-25-2007 01:59 AM
