Old 12-17-2017, 03:33 PM   #1
avlonfrg
avlonfrg is on a distinguished road
Default Coolant Level Sensor
My 2000 SC2 recently had a leaky water pump replaced which I thought would stop the low level warning light from constantly going on. I insured that the coolant level is OK. I also noted that there was no hissing when I removed the coolant cap, so I bought a replacement cap. Still no hissing. Should the system be pressurized enough to create the hissing? And if I need a replacement coolant level sensor, can someone give me a make and model number that will fit?
John W
Baltimore
Add to avlonfrg's Reputation
Rate the quality of this post and help avlonfrg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
avlonfrg is offline   Reply With Quote
Old 12-17-2017, 03:59 PM   #2
Default Re: Coolant Level Sensor
The level sensor is molded into the tank, the only way to replace it is to replace the tank. I'd start with cleaning it with warm soapy water first, usually it just gets gummed up some and the warm soapy water cleans it up. Try to rinse all the soap out of it once your done too.
Coolant level sensor? icanbeaghost Ion Tech 2 02-26-2016 07:01 PM
Coolant Level Sensor Articwhite2008 Astra General 11 10-11-2014 04:23 PM
Coolant level sensor RugerRedhawk S-Series Tech 2 02-09-2012 02:51 PM
Low Coolant Level Sensor Sundevil Saturn L-Series Tech 1 01-11-2012 05:28 AM
coolant level sensor chrisk Ion Tech 1 06-16-2011 05:37 PM
