Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 12-15-2017, 04:49 AM   #1
tjj300
tjj300 is on a distinguished road
tjj300's Avatar
2004 VUE 2.2L
Default Airbag light and PA inspection
I've just bought a 2004 Vue, and I've got an intermittent Airbag light. it looks like a bad connection somewhere, probably not the clock spring. Everything works including the horn, there are no engine codes. Does anyone know if that light is going to fail me for PA inspection?
Add to tjj300's Reputation
Rate the quality of this post and help tjj300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tjj300 is offline   Reply With Quote
Old 12-20-2017, 06:19 PM   #2
Default Re: Airbag light and PA inspection
I got bored after about 3 minutes scanning the manual...my guess is if the guys scanner doesn't pick up an air-bag fault and the light happens to stay off while inspecting it'll pass with no issue.
Manual for 2017 PA: https://www.dot.state.pa.us/Public/D...ons/PUB-45.pdf
Old 12-21-2017, 07:34 PM   #3
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
It will pass PA inspection. Airbag systems are not checked.
Add to CrewCab's Reputation
Rate the quality of this post and help CrewCab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CrewCab is offline   Reply With Quote
(Brake!) Cluster light/inspection fail blanksaturn S-Series Tech 8 04-29-2014 10:55 PM
Third brake light bulb out, failed inspection delzhand Aura General 4 08-01-2013 02:29 PM
06 vue airbag light and seatbelt light cmznj2 Vue Tech 6 01-22-2012 02:53 PM
SES light--inspection coming up! mjb S-Series General 4 06-14-2007 04:56 PM
SES light off finally... safe to get inspection? kickarse S-Series General 2 08-08-2006 06:29 PM
