Old 12-14-2017, 09:27 AM   #1
1.9 sohc
1.9 sohc has a spectacular aura about1.9 sohc has a spectacular aura about1.9 sohc has a spectacular aura about
2000 SL
Arrow Can I eliminate the higer idle that happens while rolling? (Manual trans)
I would like to have the car idle as if I was not rolling, even when I am rolling.
2000 SL, 5 speed.
If it is possible how would it be done?
Thanks
Add to 1.9 sohc's Reputation
Rate the quality of this post and help 1.9 sohc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1.9 sohc is offline   Reply With Quote
Old 12-14-2017, 10:05 AM   #2
Default Re: Can I eliminate the higer idle that happens while rolling? (Manual trans)
It is not possible. That is a baked in part of the emission control system.
Old 12-14-2017, 10:44 AM   #3
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
you should be rolling in gear anyway most of the time
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 12-14-2017, 02:49 PM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
I’d say the higher idle is a transmission saver if your foot slips off the clutch pedal. Never considered it was for emissions.
Not sure if this applies. Okay, I know it doesn’t apply.
http://www.pilotodyssey.com/carb1.htm
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 12-14-2017, 04:20 PM   #5
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Since this is a manual trans, how about putting a switch in the VSS circuit to disable the VSS signal? The cruise control will be inop, but that shouldn't matter if you don't intend to use the engine to power the car anyway. It will set VSS code(s), but do you care?
Oh, and I suppose traction control or ABS might get a bit confused. Try it and see...
Add to billr's Reputation
Old 12-14-2017, 04:21 PM   #6
RobertGary1
It helps process the exhaust while you glide before stopping at a light. Otherwise everyone would come to a stop and their pollutants from their higher power drive would process through at the light. The intersections would be a hotbed of pollitants.
-Robert
RobertGary1 is online now   Reply With Quote
Old 12-14-2017, 05:29 PM   #7
1.9 sohc
2000 SL
True but its higher when you are in gear too.
Maybe I shouldn't have mentioned geafrs.
Old 12-14-2017, 05:31 PM   #8
1.9 sohc
2000 SL
My SL doesn't even have cruise. Or Traction control.
Does VSS matter for anything else?
Old 12-14-2017, 06:32 PM   #9
RobertGary1
You mean the speed sensor in the transmission? You don't have a speedo if you do that.
-Robert
Old 12-14-2017, 07:44 PM   #10
All kinds of things quit working when the VSS is inop -- bad idea.
The high rolling idle is TERMINATED by the VSS signal, not initiated by it.
There is no way to defeat this feature as it is programmed into the emission control logic.
The issue here is what RPM are you seeing when you are in this throttle closed high idle while moving condition?
Old 12-14-2017, 09:28 PM   #11
billr
Terminating the "high rolling idle" is exactly what the OP wants to do. What else would cause a problem besides the speedo/odo if the VSS is disconnected?
OP, what do you want to do this for; to coast in neutral whenever possible to try for maximum fuel economy? Personally, I don't think that is worth the bother, but it's certainly your choice. If you want to do it, simply disconnect the VSS connector and see what happens. Ignore all the scare-mongering BS.
Old 12-14-2017, 10:15 PM   #12
High idle is only terminated by the speed signal. It is iniated by throttle closed and vacuum.
High Idle and Multiple issues 2002 Saturn SL2 Manual trans Rhiannon S-Series Tech 4 03-20-2017 07:57 PM
New Built Engine High Idle after rolling D_Lo91 S-Series Tech 2 06-07-2016 12:51 AM
Automatic Trans, rolling slightly in Neutral hein S-Series Tech 20 09-08-2010 02:34 PM
Misfire at idle 2002 SL1 Manual trans, no codes, lots done. silverslug S-Series Tech 16 04-23-2009 04:36 AM
rolling idle explanation sPuddingTime S-Series General 4 06-20-2006 11:15 AM
