Old 12-13-2017, 03:58 PM   #1
cityhawk
cityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to allcityhawk is a name known to all
cityhawk's Avatar
1993 SW2
2001 L-Series 3.0L Wagon
Default Idler pulley bearing
I stumbled across this thread where OldNuc says that you can replace the idler pulley bearing with a 6203 bearing. How hard is it to replace this bearing and is this a better idea than buying a new idler pulley?
Saturns:
1993 SW2 MT 191,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1966 Corvair Monza convertible
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Rate the quality of this post and help cityhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cityhawk is offline   Reply With Quote
Old 12-13-2017, 04:02 PM   #2
cityhawk
cityhawk's Avatar
1993 SW2
Default Re: Idler pulley bearing
Perhaps this bearing?
https://www.autozone.com/batteries-s...e&newYmme=true
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-13-2017, 04:10 PM   #3
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Not if the picture is correct. What is shown is open on at least one side, you need "double-sealed". 6203 defines the basic bearing size, but suffixs like "ZZ" specify sealing, shielding, grease used, grade, etc. The price seems a bit high, but I usually go to a commercial bearing supplier, and it has been a while since I bought any.
Add to billr's Reputation
Old 12-13-2017, 09:06 PM   #4
cityhawk
cityhawk's Avatar
1993 SW2
Thanks BillR
Does anyone have an answer to my first post in this thread?
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-13-2017, 09:28 PM   #5
billr
Do you mean how hard is it to do? I haven't done one of those but think it would be fairly easy. Certainly some pressing is involved, but it is a small bearing with symmetric housings and such; much easier to set up properly than a front wheel bearing. And, probably no fierce snap-ring! Regardless, avoid any use of a hammer during either the removal or installation. For a small simple bearing like this, a "press" could be merely a jack, socket/pipe, and a big weight (like a car) to push against.
I did take a peek, those 6203 double-sealed bearings seem to be available on-line in the $2-5 range. The high-priced $5 one is SKF.
Old 12-13-2017, 09:59 PM   #6
You can replace the bearing in a Metal idler or tensioner pulley, plastic pulleys are not simple to do. The primary criteria is that the outer rim of the pulley does not have a sharp edge worn into it by the belt, if it does it is a paper weight. As long as you apply force to the outer race ONLY you can swap it out/in with a hammer and socket, it is not in there very tight. You need a quality double sealed bearing size 203. The "6" indicates the quality fit and is about all you will see so a 6203 double sealed is what you want. Every manufacturer has a slightly different methods of indicating double sealed so the code is of minimal interest. Google your location for Motion Industries or Bearing Supply to see what is close. A decent quality will be in the $5,00 range. Swapping out metal for plastic may be the better choice as long as you can afford the price difference which should be minor.
Old 12-13-2017, 10:32 PM   #7
cityhawk
cityhawk's Avatar
1993 SW2
Thanks Nuc. How about I replace the whole thing with one of these:
https://www.rockauto.com/en/moreinfo...267017&jsn=345
or
https://www.rockauto.com/en/moreinfo...sn=346&jsn=346
Both are steel.
If so, either one preferable?
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-13-2017, 10:43 PM   #8
cityhawk
cityhawk's Avatar
1993 SW2
There's also this one, if I want to buy one locally quickly:
https://shop.advanceautoparts.com/p/...m=idler+pulley
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-13-2017, 10:51 PM   #9
cityhawk
cityhawk's Avatar
1993 SW2
Apparently, there's a Motion Industries in Somerville, which is close (my work takes me into Somerville daily).
I think my pulley is still ok, though I believe it's original (making it 25 years old). I'm just trying to find the easiest and quickest quality fix.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-13-2017, 10:56 PM   #10
If it wobbles and makes noise it is due for replacement and if it is original then a complete replacement is best approach.
Old 12-14-2017, 06:43 AM   #11
cityhawk
cityhawk's Avatar
1993 SW2
I meant the pulley itself. I t is making a noise... wobbles a little so the bearing must be shot... But yeah, I was thinking of replacing the whole thing.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-14-2017, 04:56 PM   #12
craftsman70
craftsman70 is on a distinguished road
1998 SL1
I went through this last spring. I bought the bearing but couldn't get the old one out of the pulley since I don't have access to a press. So then I just went ahead and replaced the entire pulley. While at it, I recommend you also replace the pully on the tensioner and the belt itself. One last thing, locally I could only find some of the pulleys in plastic. I ended up having to order both my tensioner and idler pulley online in order to get metals ones.
Add to craftsman70's Reputation
Rate the quality of this post and help craftsman70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
craftsman70 is offline   Reply With Quote
Old 12-14-2017, 06:39 PM   #13
cityhawk
cityhawk's Avatar
1993 SW2
I replaced it today with the pulley listed above from advance auto parts. What a difference! For a number of years when I started the car on the really cold day it made a sound like a power steering pump that was low on fluid. Eventually the sound died down as the car warmed up. I just always assumed that sound was the power steering pump. Recently that sound got louder and kept on going after the car warmed up. I thought maybe I really was low on power steering fluid so I checked that and it was fine. Then the sound started to get louder and raspier and didn't sound so much like a power steering pump anymore. I loosen the tensioner on the belt and tried spending some of the police and the tensioner seemed a little bit crusty and a tiny bit wobbly. Given that that's the original tensioner that's 25 years old and 182,000 miles on it I figured that was the likely culprit. It was an inexpensive thing to try. So I tried it and Vpila! I don't remember a time when the engine was so quiet.
As to the tensioner, I replace that with an oem one two or three years ago.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-14-2017, 06:47 PM   #14
cityhawk
cityhawk's Avatar
1993 SW2
By the way, when I took out the old one the bearing was really crusty.
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
Old 12-14-2017, 07:41 PM   #15
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Mine makes that exact noise, I figured it was the PS pump as well, but maybe Ill try the idler and tensioner and replace the belt while I am there.
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cgg17 is online now   Reply With Quote
Old 12-14-2017, 07:53 PM   #16
cityhawk
cityhawk's Avatar
1993 SW2
btw, I tried spinning some of the pulley, not spending the police. Damn speech to text. it's good, but still not perfect!
Saturns:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
idler pulley bearing BLKSATSC2 S-Series Tech 2 03-14-2015 07:13 PM
Part # for idler pulley bearing rocket321 S-Series Tech 3 07-13-2013 10:30 AM
Idler Pulley Bearing 203F vs. 203FF Saturn1998SL1 S-Series Tech 5 05-10-2012 09:41 PM
Are the serp belt idler pulley and tensioner pulley the same part - 93 DOHC?? 93goldsl2 S-Series Tech 6 04-10-2010 01:03 PM
Replacing the idler pulley bearing coolgreany S-Series Tech 8 12-12-2004 08:44 AM
