Old 12-13-2017, 02:52 PM   #1
Cavell
2004 VUE 3.5L
Default security light?
found a seller with 03 v6 w/80k miles he says it has a security light issue and will randomly go into limp mode. i read many threads on limp mode and throttle issues with broken wire causes but am not familiar with a security light leading to limp mode. is this a different issue or the security system shutting down the vue? or do i need to see if it has codes first?
Add to Cavell's Reputation
Old 12-13-2017, 04:56 PM   #2
waiter21
2003 VUE 2.2L
Default Re: security light?
I'm not sure if the Passlock system would cause a limp mode...
However, If you wish to bypass the Passlock system, this is how I did it..
http://www.saturnfans.com/forums/sho...d.php?t=215634
Add to waiter21's Reputation
Old 12-13-2017, 07:03 PM   #3
I believe you're describing two separate problems. Reduced power mode in Saturn speak (commonly known as limp home mode) and Passlock security. Reduced power mode involves the ECM, pedal, throttle and associated wiring. The cel/mil should be on with stored codes. Reduced power mode isn't a security issue and shouldn't turn on security. Passlock security has four modes; ON, Off, blinking slowly and flashing quickly. Passlock security doesn't turn on reduced power mode. When Passlock flashes quickly, injectors are disabled to prevent a car thief from trying to drive away.
Old 12-14-2017, 02:31 PM   #4
Cavell
2004 VUE 3.5L
80k miles is nice. almost as low as the vues with bad vti trans w/100k miles which seem common. i did see an 03 w/31k miles for crazy money. dealer wants $7k? he is adding $4k for the miles?
2002 l200 security light and service WRENCH light treetoplamar L-Series Tech 12 06-24-2017 02:06 PM
2002, L200 Security Light & Service Engine Light Bob McIntyre L-Series Tech 3 12-24-2016 09:40 PM
01 Sl2 service (wrench) light and security light just came on. what's wrong now lol? Jesse Pinkman S-Series Tech 11 03-14-2015 12:36 PM
- 2002 Saturn SL2 - Security Light & Wrench Light on Toolman11k S-Series Tech 2 10-02-2012 08:09 AM
help asap...security light wrench light Ruger141 S-Series Tech 7 01-28-2011 03:08 PM
