Old 12-13-2017, 01:15 PM   #1
onlinebiker
onlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of light
Default How do I bench test an oil pressure sender?
How do I test?
An Ohm meter shows a closed circuit at zero pressure. Using regulated air to the sender, I see no difference in resistance up to 80 psi.
The manual calls 13 psi at idle, 80 psi cold at 2000 rpm - but give no test for the switch..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 12-13-2017, 01:54 PM   #2
Default Re: How do I bench test an oil pressure sender?
The switch opens at 5-7psi. If you are discussing the 91-92 SENDER then the resistance changes with pressure.
Operating oil pressure specification is based on engine and oil warmed up to operating temperature. This implies a 15-30 minute drive at 45-65 mph. The specification is 13 psi at idle and 36 psi at 2000 RPM. The bypass is based on cold oil conditions and it begins to open at 72-73 psi and oil pressure maintained <80 psi up to 2500 RPM.
Old 12-13-2017, 02:30 PM   #3
onlinebiker
I tried an ohm meter - and the circuit shows closed. Added air pressure starting at zero and increasing gradually to 80 psi. No change in resistance.
Repeated with a new switch I just bought. Same results.
Hmmmmmm.
Am I missing something? Reading taken across terminals.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 12-13-2017, 04:41 PM   #4
Yes, read between either pin and the HEX body of the switch.
Old 12-13-2017, 05:37 PM   #5
onlinebiker
Happy Re: How do I bench test an oil pressure sender?
Many thanks!
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Oil pressure sender Cavell Vue Tech 6 02-25-2017 08:31 PM
How do you bench test a wiper motor? trottida S-Series Tech 13 11-21-2016 09:57 PM
O2 sensor failed, but works during a bench test? PlasticCarsRock S-Series Tech 10 01-12-2013 01:52 PM
Visual and bench test of Oxy sensor. rbar S-Series Tech 15 05-27-2012 12:58 AM
How do I bench test a starter motor? auxmike S-Series Tech 5 03-07-2003 09:53 PM
