Old 12-13-2017, 06:10 AM   #1
cookie1400
cookie1400 is on a distinguished road
2004 VUE 3.5L
Default no movement in any gear
Hey Guys,
So i had my tranny rebuilt 2 years ago on my 2004 Vue V6 3.5. The other day it shuddered really hard at take off. Next stop sign no movement. i barley made it home frome a block away. I would only go into gear if i turned the engine off started and put in gear again. iv'e been doing drain and fills with honda dw-1. First i thought filter was clogged i did a drain and fill not much metel in there. now im thinking its the TCC solenoid but im at a loss. on startup theres a grinding/buzz noise that seems to be coming from the flywheel/torque converter area. Restricted atf pump? I just dont know no CEL so i figure its something internal which totally sucks. any input? Also this makes me wanna get an inline atf filter anyone try one of those?
Add to cookie1400's Reputation
Rate the quality of this post and help cookie1400 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cookie1400 is offline   Reply With Quote
Old 12-13-2017, 06:38 AM   #2
cookie1400
2004 VUE 3.5L
Default Re: no movement in any gear
update... so out of curiousity i removed to torque converter drain plug. absolutely nothing came out not event a drop. so atf pump right? maybe ill start it shift through gears and pull it again to see if anything comes out.
Old 12-13-2017, 09:23 AM   #3
atikovi
CEL won't tell you much about the transmission. Think you need a more advanced scan tool to read the transmission module codes. And I didn't know you could drain the torque converter on these cars. If nothing came out of the plug, check the fluid level and top it off.
Add to atikovi's Reputation
Old 12-29-2017, 10:17 AM   #4
natenatenate
natenatenate is on a distinguished road
That definitely sounds like the pump went out.
Add to natenatenate's Reputation
Rate the quality of this post and help natenatenate reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
natenatenate is offline   Reply With Quote
Engine movement Ndubs S-Series Tech 3 09-22-2013 08:41 AM
Help; No forward movement!!!!!! Needle750 L-Series Tech 5 01-20-2012 08:02 PM
96 sc 5 speed no movement rbuffum S-Series Tech 7 04-17-2007 01:21 PM
'96 SL1 Frt wheel movement 94sl2guy S-Series Tech 11 09-03-2005 04:57 PM
Movement Sounds DMK's Vue Vue General 7 07-15-2003 06:11 PM
