Old 12-12-2017, 04:23 PM   #1
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
Default 98 sl2 not turning over
98 sl2 5 speed
Thanks to everyone who helped with previous issues
I have 2 problems now.
1st I am getting a p300 multiple misfires error code
I have replaced bosch platnium plugs with NGK copper, new wires, coils (off of running car and tested) icm, cleaned all surfaces icm connects to including bolts
Seems to run fine during normal driving, but when I really get on it and rpm are 5500 to 6 k shifting from 3rd to 4th get the blinking ses light
clear codes drive in a more lawful manner and no light.
Problem 2 Life was good with previous info was starting fine working on last problem (see above) when last night it would not turn over lights came on everything seemed normal. I am suspecting the clutch switch. Any seconds or better ideas?
This happed when I first got the car back, mechanic swears he did nothing to it, it worked when he started it and brought it back.
marmitage
03 vue Yellow Mom's,
03 Vue Silver mine,
02 Vue Red #2 Daughter's
98 SL2 project, 99 Sw2
Add to marmitage's Reputation
Rate the quality of this post and help marmitage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marmitage is offline   Reply With Quote
Old 12-12-2017, 04:38 PM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: 98 sl2 not turning over
How old is the starter? Was the engine warm when the no crank occurred? These starters tend to announce their impending failure with a no crank when hot episode.
A clutch switch that fails to close will also interrupt the starter circuit leading to no crank. The connector can be jumped with a piece of wire to check.
As for the high rpm P0300, I'll let the experts handle than one.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
98 SC2 Fan not turning on. strain S-Series Tech 2 05-25-2011 04:45 PM
Vue Keeps turning off DM158 Vue Tech 1 12-23-2010 11:25 AM
Pop when turning Cheyne S-Series Tech 4 02-17-2010 07:32 PM
Problem with engine turning on then turning off, everything is on radio, lights, air fatimaknapp Ion Tech 6 12-28-2006 04:02 PM
L 200- Turning on fan Saturn5000 L-Series Tech 0 12-18-2002 01:26 PM
