Old 12-07-2017, 06:38 PM   #1
livelyone
livelyone is on a distinguished road
Dazed 2007 Aura 15 OBD Codes
Please tell me I am not screwed.. Noticed a few days ago that the car wasn't starting, like either the battery was being drained or was no good, but was fine after being jumped. Today while driving on the highway, the speedometer quit working, the traction light and check engine light came on, then rpms got high, and the car would no longer shift.
It threw these 15 codes..
U0100
U0073
P1818
P1816
P1810
P0977
PO976
P0973
P0751
P0741
P0722
P0705
P0603
P0602
P0601
All of these are point to come huge ECM error.. has anyone dealt with this? Can this be something else besides a faulty ECM?
Add to livelyone's Reputation
Rate the quality of this post and help livelyone reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
livelyone is offline   Reply With Quote
Old 12-07-2017, 07:15 PM   #2
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Default Re: 2007 Aura 15 OBD Codes
Half of these codes are low voltage codes and ecm communication lost codes. Have the battery tested, replace if it's bad. If good, check charging system.
A bad battery with a bad cell or low voltage will cause all kinds of things to happen.
Also helps to know what kind of vehicle you have. XE? XR? 2.4? 3.5? 3.6? Year?
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is online now   Reply With Quote
Old 12-07-2017, 08:47 PM   #3
livelyone
Sorry about that, it's a 2007 Saturn Aura XE 3.5.
I'll be switching out the battery and seeing if that's what it is.
Old 12-08-2017, 07:58 PM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
dont forget to reprogram windows after power loss
Add to onefunkar's Reputation
Old 03-02-2018, 03:26 PM   #5
imaddicted2u
imaddicted2u is a jewel in the roughimaddicted2u is a jewel in the roughimaddicted2u is a jewel in the roughimaddicted2u is a jewel in the rough
2008 AURA XE
I did not know this...thanks
Programming the Power Windows
If the battery on your vehicle has been recharged,
disconnected, or is not working, you will need to
reprogram the driverís power window for the express-up
feature to work. Replace or recharge the vehicleís battery
before reprogramming.
To program the driverís window, follow these steps:
1. With the ignition in ACC/ACCESSORY, ON/RUN, or
when Retained Accessory Power (RAP) is active,
close all doors.
2. Press and hold the power window switch until the
window is fully open.
3. Pull the power window switch up until the window is
fully closed.
4. Continue holding the switch up for approximately
two seconds after the window is completely
closed.
The window is now reprogrammed
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2007 Vue CEL, 33 different codes! guitarjesus Vue Tech 2 08-20-2017 07:17 AM
2007 Aura XR Spitting Out 24 Codes hill307 Aura General 12 06-22-2012 02:00 PM
2007 VUE Codes? HELP! DA VUE Vue Tech 3 08-21-2010 01:44 PM
2007 Aura XR vs 2007 Passat 3.6 VR6 Seasoned Aura General 5 12-09-2006 03:12 PM
2007 Aura XR vs 2007 2.0T passat sedan, which to buy? fantarain Aura General 43 11-26-2006 11:39 AM
