Old 11-30-2017, 06:57 PM   #1
Cheesesteak
Cheesesteak is on a distinguished road
2004 VUE 3.5L
Default What's causing this vibration???
I'll try to describe this as best I can. You know how some highways have rumble strips by the shoulder to alert drivers who stray off the road by causing a noisy and bumpy sensation? My Vue seems to act like it is hitting rumble strips on an off-&-on basis. Not as violent as real strips. I notice it when I am on I-95 doing 65 +/- mph. It's smooth for a couple seconds then vibrates for a couple, smooth for a couple then vibrates for a couple, and so on. Not sure what else I can say to describe it other than to say I feel the source seems to originate for the passenger side. Maybe. It never goes away. I presume it is there as slower speeds too but, with the crappy, bumpy roads around here, I don't notice it.
Anyone else had this happen or know what might be causing it? Or how to fix it?
Just in case my Vue info is not showing, I have a 2004 AWD with the Honda V-6 and transmission. About 73,500 miles. Changed tranny fluid in Sept 2016 (at 67,522 mi.) Right-side Axle shaft in October 2016 (at 67,873 mi.) New front brake pads & rotors in May 2017 ( at 70,103 mi.)
Add to Cheesesteak's Reputation
Rate the quality of this post and help Cheesesteak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheesesteak is offline   Reply With Quote
Old 11-30-2017, 09:32 PM   #2
BobWolf
BobWolf will become famous soon enough
Default Re: What's causing this vibration???
It could be any number of things; tires, brakes, steering, suspension drive line, transmission, even body/frame Was the vehicle ever involved in a wreck? Even what appears to be a minor one can affect the frame, or cause other problems.
The only way to find out is get the vehicle off the ground and check everything hub to hub and let us know what you find and see.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Old 12-01-2017, 08:20 PM   #3
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Cheesesteak,
Have you looked at the center support bearing, changed the fluid in the RDM, or in the transfer case? How about wheel bearings? Another couple of things that I would look at, the U-joints in the rear drive shaft. And on center support bearing.. Don't let soft rubber around it fool you... One way to diagnose anything in the drive shaft, pull it...the car will still run fine, but if noise stops, than you have a starting point.
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
Add to lord_varon's Reputation
Rate the quality of this post and help lord_varon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lord_varon is offline   Reply With Quote
Old 12-03-2017, 09:43 AM   #4
Cheesesteak
2004 VUE 3.5L
Thanks to the two of you that replied. I probably should have noted that I have limited mechanic experience and do not have a garage. (Live in a condo).
I read several other posts using 'vibration' as the search word. Many 'cures' point to needed wheel balancing. These posts seem to always describe a steady vibration. Because my vibration fades in & out over & over again, I thought the wheels shouldn't be the first place to look. Is it possible for the shudder to be cause by unbalanced wheels AND be fine one second and then bumpy the next?
I have recently noted that the vibration does not come thru the steering wheel. Maybe this fact helps with diagnosing the problem? I'd prefer NOT going to the mechanic's shop and giving them a blank check to go nuts checking dozens of things if I can avoid it.
Old 12-12-2017, 04:43 PM   #5
goBoating
goBoating will become famous soon enoughgoBoating will become famous soon enough
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Really difficult to say. But, you cannot rule out wheel balancing. If two wheels on the same end (front or back) are both slightly out of balance, they may sometimes cancel each other out. Go around a turn (one wheel had to roll further than the other) and the canceling out might stop and let the wobble show through.
Wheel balancing is relatively inexpensive. I'd try that first. After that, it gets into mechanical stuff. Our 2004 V6 Vue 2wd has had both front wheel bearings fail.
Odd thing happened with our wheel bearing issue. Long before the wheel bearing started making noticeable noise our ABS brake function stopped working - blinking ABS light. Still relatively safe to drive - just had conventional brakes. As it turns out, when we had the wheel bearing replaced we asked our shop to quote fixing the ABS. They said, to let them do the wheel bearing and see if that fixed it. Apparently, the wheel speed sensors for the ABS system are extremely finicky. The very slight wobble in the axle from the worn bearing through the sensor off. Since the ABS couldn't tell how fast the axle was spinning it disabled itself. Replacing the bearing fixed the ABS.
Don't Tread on Me
A strict constructionist fiscal conservative free market freak I am.
"The problem with socialism is that you eventually run out of other people's money." - M. Thatcher
Add to goBoating's Reputation
Rate the quality of this post and help goBoating reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goBoating is offline   Reply With Quote
Old 12-15-2017, 08:29 AM   #6
cjhsa
cjhsa is a jewel in the roughcjhsa is a jewel in the roughcjhsa is a jewel in the rough
Get all four wheels/tires/ road force balanced. This means they the tires are put under standard pressure while being balanced, not just spun in the air. If that doesn't help. have them check the wheel bearings. This can be hard to diagnose even by the best of them, but they should use a stethoscope to attempt to determine which, if any, might be bad (assuming that it isn't easy to find). Note that on the AWD model a bad bearing on the front driver's side wheel can sound like a bad transmission, so be aware.
It's also possible you have a bad tire. Sometimes they can de-laminate internally and you have no way to tell without unmounting the tire.
2007 VUE AWD V6 3.5L
Add to cjhsa's Reputation
Rate the quality of this post and help cjhsa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cjhsa is offline   Reply With Quote
Caliper/brake pad causing steering wheel vibration? Dirkk S-Series General 5 01-22-2014 04:39 PM
SRI causing CEL p0101 mercer Ion Mods 10 10-12-2013 10:17 PM
Oil Leak - What's causing it? Growser S-Series Tech 7 09-17-2008 04:28 PM
What is causing this? Yenko S-Series Tech 4 07-21-2008 08:07 AM
Used tire causing vibration in steering wheel. foo S-Series General 7 07-16-2008 03:42 AM
