Old 11-26-2017, 06:55 PM   #1
joshuah459
joshuah459 is on a distinguished road
Default Transmission leaking from filter pan?
A few months ago my 2007 Saturn aura xe began to lose acceleration power and upon investigation it's leaking transmission fluid. The rate it leaks seems to be fairly constant. It's a fairly large leak as it is entirely out of fluid within a week. Anyway we parked it for a while and now that I have some money I wanted to look further into the issue. It looks like it's leaking from the pan exactly opposite of the oil drain bolt. I can't see a stream coming from any higher and when I wipe it off it immediately resumes. Have any of you guys seen anything like this? What might have caused it, or what else it could be...
Add to joshuah459's Reputation
Rate the quality of this post and help joshuah459 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joshuah459 is offline   Reply With Quote
Old 11-26-2017, 09:39 PM   #2
pierrot
pierrot's Avatar
Default Re: Transmission leaking from filter pan?
Welcome to SaturnFans, joshuah459!
Yes, this is a very large transmission fluid leak. It seems that you should have a four speed automatic, but according to some catalogs it's possible for there to be a six speed automatic as well. Which one do you have?
What is this vehicle's mileage?
Has the transmission been serviced recently?
Is there any ATF leaking from the axle seals?
Possible reasons for this leak: loose or missing transmission oil pan bolt/bolts; weak gasket needing replacement; damaged trans. oil pan or fracture in the case (both less likely).
278,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Oil filter housing leaking! Wolfc70 L-Series Tech 13 04-22-2014 05:17 PM
Leaking Oil filter cap/gasket C Trus Ion Tech 12 12-27-2011 09:16 AM
Fuel filter is leaking horribly!!! Help please! munky000527 Ion Tech 2 01-23-2011 02:29 AM
cabin filter and inline transmission filter? mrtube Vue Tech 10 12-04-2009 07:38 PM
Oil Filter Canister Leaking bushton4 Vue Tech 5 11-16-2008 07:23 PM
