Old 11-23-2017, 09:24 PM   #1
Mikey722
Mikey722 is on a distinguished road
Default Tire size for 98 SL1 with 15" rims
I have a 98 SL1 that I recently purchased and have just rebuilt the front end with new moog inner & outer tie rods, control arms & monroe struts. I got it aligned and now need to get new tires. Whoever owned it before swapped out the stock 14" rims with Saturn 15" alloy rims. I know the stock tires for this car are 170/70/14 so I'd like to get the closest matching 15" tire. Any input or advise besides purchasing 4 new 14" rims would be greatly appreciated
Add to Mikey722's Reputation
Rate the quality of this post and help Mikey722 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mikey722 is offline   Reply With Quote
Old 11-23-2017, 10:12 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Tire size for 98 SL1 with 15" rims
My stock tires are 185/65R15. Sorry for the repeat, I said the same thing in the other thread.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-23-2017, 10:49 PM   #3
Stock size's available (models found on from the factory):
175/70R14 (SL/SL1/SC1/SW1)
185/65R14 (SL/SL1/SC1/SW1/SWP)
185/65R15 (SL1/SC1/SL2/SW2)
195/60R15 (SC2)
14's are steel only, 15's could be steel or alloy though to my knowledge 100% of the SC & SC2 models got alloys from the factory.
That said, 185/60R15 is closest to 175/70R14 assuming the tires actual size is what it's advertised as (generally they're off by just enough to measure).
Old 11-23-2017, 11:17 PM   #4
The 195/60 is wide enough to throw crap down the sides of the car and is a smaller diameter than the 185/65 tire. A 195/65 tire will fit and is a larger diameter than the 185/65. The SC-1 and SC-2 were available with either 15" steel or 15" aluminum.
Old 11-24-2017, 02:29 AM   #5
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
185/65R15 was the stock 15” tire,
But a 205/60R15 runs a lot better on the highway.
Play around with the “Tire Comparison” tab here...
https://tiresize.com/calculator/
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 11-26-2017, 02:24 AM   #6
JerryHughes
JerryHughes's Avatar
1997 SL
Last time I changed tires, I bought them at Walmart. I wanted them to put on a wider 14 inch on my 97 SL but they would only put on what the book called for. No discussion---told me it was either that or take my business elsewhere. Best price I could find, so I bought them.
Old 11-28-2017, 12:50 PM   #7
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
Yep, Walmart is a PITA.
I like 205/60R15's but usually have to settle for 195.
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 11-28-2017, 12:54 PM   #8
JerryHughes
1997 SL
Yeah, but again, they gave me the best deal and I looked at local tire companies and even Costco! Still couldn't beat Wally's price.
Tire size for 15" rims rpl3000 S-Series General 5 11-04-2011 09:25 AM
Tire size for 16" alloy rims djgriffi Vue Mods 5 10-29-2010 10:15 AM
Max tire size on SL1 with 16" rims? aaron7 S-Series General 3 07-12-2009 07:36 PM
17" Konig Unknown, size? tire size? 92[SL2] S-Series Tech 1 05-14-2007 11:45 PM
Best tire size for my SC2 15" Rims sspriest Mods and Performance 2 04-12-2001 10:50 AM
