Old 11-22-2017, 12:33 PM   #1
Upstate Saturn
Upstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really nice
Upstate Saturn's Avatar
2001 SL2
Default After changing ECTS, gen 3 temp gauge at 1/2, is this okay
I recently had the ECTS and connector changed as the car was boiling over before reaching halfway on the temp gauge. Now the temp gauge stays at 1/2 at normal operating temp, and the fan kicks on at 5/8. This seems to be fine but as the gauge consistently read 3/8 for many years, I thought I should ask. I changed the ECTS out about 8 or 9 years ago, so it's been brass-tipped all that time.
2001 SL2 manual - original owner - remanufactured engine at 228k miles, December 2015
1992 SL1 - bought used in '93, totaled in '00 at 170k miles, drove it cross-country a lot!
Add to Upstate Saturn's Reputation
Rate the quality of this post and help Upstate Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Upstate Saturn is offline   Reply With Quote
Old 11-22-2017, 01:01 PM   #2
toggenburg
toggenburg's Avatar
Default Re: After changing ECTS, gen 3 temp gauge at 1/2, is this okay
Did the replacement ECTS stop the boiling over issue?
Whoever did the replacement, was the connector and wiring clean & bright?
If so, and the gauge now reads slightly different I would just ignore the old position and accept the new needle position as your specific car's NORMAL.
These dash gauges are not pinpoint-reliable....if you need more reliable data, use a live data scanner.
Old 11-22-2017, 02:37 PM   #3
As long as it started at the left end of the scale and slowly came to 1/2 then don't worry about it. If you installed a new thermostat that will result in higher than normal initial readings.
A snap jump to 1/2 is a PCM sign that the ECTS is failed.
95 SL1 ECTS/Temp gauge sensor? SocomX S-Series General 6 02-02-2014 09:59 PM
ECTS/Temp Gauge/Thermostat question Murander S-Series Tech 6 04-08-2012 06:17 PM
New ECTS...still have Hot Temp Gauge 2NDSOUT S-Series Tech 6 05-22-2008 09:20 AM
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 11:58 AM
Changing the ECTS Coolant Temp Sensor (with pictures) auxmike How-To Library 43 10-02-2005 01:51 AM
