Old 11-20-2017, 01:32 AM   #1
badger1997
badger1997 is on a distinguished road
2002 SL1
Default Busted bolts on fuel filter bracket for SL1
So, I'm trying to replace the fuel filter on my daughter's 2002 SL1 and of course the rusted to hell bolt broke off when trying to remove the bracket.
I've read the forum over and over again, but I'm hoping for a little more guidance from those of you who've done this before.
I've tried to get the filter out of the bracket without taking it off, but have made no progress. It might be because it's just to stuck on there given the climate it's been in (I'm in Minnesota), but it's not budging even with the two tabs pushed out via screwdrivers. Any tips?
I'm a little bit leery about drilling out the bolts and tapping them or just drilling new holes as I've seen suggested. Never done that before and the presence of gas where I'm going to drill makes me nervous.
So any tips/suggestions would be very helpful. Thanks.
PS: First time poster, but I've been lurking on this forum since we bought this car as a fixer-upper this summer. Can't say how helpful it's been and I may be coming back for more help after I get the fuel filter installed because I doubt it's the last thing I'll have to fix on this car, lovingly known as Hazel due to the three letters on its plate being HZL.
Add to badger1997's Reputation
Rate the quality of this post and help badger1997 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
badger1997 is offline   Reply With Quote
Old 11-20-2017, 08:29 AM   #2
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Re: Busted bolts on fuel filter bracket for SL1
Ours busted, and we drilled and tapped them. Actually my teenager did all the busting, drilling, and tapping. As long as you are up on ramps it is not bad, and I didn't feel it was a hazard with the gas.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-20-2017, 10:59 PM   #3
macbox
macbox is on a distinguished road
macbox's Avatar
Drilling isn't a big deal in that spot, you aren't using heat, but getting a stuck bolt next to the fuel line loose with an acetylene torch would be a real hazard.
The vehicles south of the rust belt generally don't have the rusted bolt problem.
#4, 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#5, 1998 SW2m, rebuilt at 126K, Totaled at 205K miles.
#7 1995 SC2, 121K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Fuel Filter Bracket Sat_98SC1 S-Series Tech 3 01-21-2011 11:26 PM
Fuel Filter Mounting Bolts busted ratwhisperer S-Series Tech 3 08-31-2010 11:32 PM
How Do I Remove the Fuel Filter Bracket? rockky S-Series General 2 01-17-2010 09:02 AM
'02 Fuel Filter Bracket Bolt MiSaturn S-Series Tech 2 10-13-2007 08:29 AM
New S-Series Fuel Filter Bracket Bolts cris_thomas S-Series Tech 4 01-05-2005 10:19 AM
