Old 11-19-2017, 08:21 PM   #1
02 LW300
02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough02 LW300 is a jewel in the rough
02 LW300's Avatar
2002 L-Series 2.2L Sedan
Default Wet carpet on the passenger side.
Now that the serious winter rain has arrived my car has wet carpet on the passenger side. It gets very wet, I have been using the commercial shop vac at work to keep it under control. Today was the first decent day on my weekend so I started diagnosis. This is a sunroof car so I started there. With the roof open I could reach the front drains, so with a rubber tipped blow gun I gave it a little air. No restriction in the drain hoses. Next I removed the trim and the passenger side fuse panel. I have the FSM and have read the drain descriptions and reviewed the drawings. I also have a sunroof parts car apart to check locations. I could not see the bottom of the drain hose, it comes down inside the pillar and ends just above the rocker panel. The rocker panel has rubber drain plugs in four spots along the bottom. I pulled out the front one for inspection, no problems found-no dirt or rust present. Next a pitcher of water down the right front sunroof drain, the problem was obvious. There is a factory hole with a factory sticky patch over it. The sticky patch was about 1/8 too low and a nice stream of water was squirting out just behind the fuse panel. This car lived on the dry side of Washington State since new so this was probably not noticed. Now it lives in the Willamette Valley of Oregon, it rains from the middle of October until mid July. We have some really good asphalt based sticky stuff at work that I will put over the clear gorilla tape patch. I will leave the trim off and the carpet up to dry and observe. Should know by next weekend if this fixes it.
Happy Thanksgiving to all!
__________________
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 11-20-2017, 08:33 AM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: Wet carpet on the passenger side.
Sounds like your fix will be much better than the factory attempt. Good Job!
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Passenger Carpet Soaked With Water legaspi89 L-Series General 6 10-03-2015 09:16 AM
Passenger side carpet wet. SaturnGal21 L-Series General 8 04-28-2014 10:01 AM
carpet soaked on passenger side... don't have a sunroof. Mgg4591 S-Series General 23 11-04-2010 04:54 PM
Soaking wet passenger side carpet giants55 S-Series General 6 02-21-2009 07:13 PM
coolant passenger side carpet spareribs L-Series Tech 7 04-15-2008 09:13 AM
