Old 11-19-2017, 09:57 AM   #1
dmayorgap
dmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura about
dmayorgap's Avatar
2008 VUE 3.6L
Default Trans slip
Hi, my transmission slip when reving high, but when reving low the shifts are flawless, what could it be the problem?
Thanks
David M.
Chevrolet Captiva Sport AWD V6 3.6
Add to dmayorgap's Reputation
Rate the quality of this post and help dmayorgap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmayorgap is offline   Reply With Quote
Old 11-20-2017, 09:01 AM   #2
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default Re: Trans slip
read current threads about 3-5-R waveplate failure for 6T70 trans. GM warranties the trans to 10 years or 120K miles.
Good luck
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gm7 is offline   Reply With Quote
Old 11-20-2017, 03:35 PM   #3
dmayorgap
dmayorgap's Avatar
2008 VUE 3.6L
Hi, i dont think this issue is the known waveplate failure since my VUE is 2010, what would it be the correct procedure to measure the transmission fluid?
Thanks
David M.
Old 11-21-2017, 09:46 PM   #4
gm7
gm7's Avatar
2009 VUE Red Line
Thanks
You can find it on line. For the 6T70, its downright fussy. If you haven't changed your trans fluid, I suggest warm the engine/trans and dump it, drain for 30 min. and refill with 5 qts. Dextron VI...then you know your level. Lots of extra fluid in the torque converter btw.
Old 11-26-2017, 08:17 AM   #5
dmayorgap
dmayorgap's Avatar
2008 VUE 3.6L
Hi gm7, thanks for your input, i've testing the vue and i can say it only slips when shifting from 2nd to 3rd gear, fluid level is ok and color is transparent and loosing its red color, a bit brownish, you think with a flush it will stop slipping?
Thanks
David M.
Old 11-26-2017, 06:59 PM   #6
gm7
gm7's Avatar
2009 VUE Red Line
Thanks
Generally....unless fluid is extremely contaminated, changing fluid won't stop slipping.
You need to run codes thru your OBDII with a code reader:
https://www.yourmechanic.com/article...by-jason-unrau
Google and code you find if any. Your transmission may have a bad speed sensor, bad shift solenoid, plugged valve body, or clutch pack or something else. Maybe a clutch pack pressure issue for example.. Codes are the first place to look after checking fluid level.
Good luck.
Old 12-21-2017, 07:33 AM   #7
dmayorgap
dmayorgap's Avatar
2008 VUE 3.6L
Hi gm7, why should a bad speed sensor could cause trans slipping? Maybe with a trans relearn procedure it could fix it? Thanks
David M.
03 Ion III auto Trans starting to slip golfish Ion General 7 10-02-2015 11:58 AM
Leaking Trans Input Seal Causing Clutch Slip? zzyx7 S-Series Tech 2 05-17-2010 09:26 PM
95 SL2 auto trans reverse delay & slip? detroitdan S-Series General 6 08-16-2009 04:25 AM
95 sl trans....slip n slam! green95sl S-Series General 5 06-05-2006 11:42 AM
L series Trans Slip texneus Miscellaneous Tech 0 07-16-2003 02:49 PM
