Old 11-18-2017, 03:34 AM   #1
CarFlunky
CarFlunky is on a distinguished road
Default Tasteful Aftermarket Wheels
I have a ‘97 sc2, and I am looking to get rid of the stock steel wheels that have the plastic hub caps. Does anyone have any good pictures of aftermarket wheels on an sc2, or any suggestions for good and tasteful aftermarket wheels?
Also as a follow up question. There would be a lot more options for aftermarket wheels if I could do a 4 to 5 lug conversion. I couldn’t find any kits online for a Saturn S-series 5 lug conversion. Does anyone know of any sites or companies that do that kind of thing for an Sc-2?
Add to CarFlunky's Reputation
Rate the quality of this post and help CarFlunky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CarFlunky is offline   Reply With Quote
Old 11-18-2017, 12:09 PM   #2
Default Re: Tasteful Aftermarket Wheels
Looking to stay with stock diameter, or thinking of going +1?
Local shops only or buying off internet?
Not interested OEM rims?
Budget, or sky is the limit?
The last SC2 was built 15 years ago, so aftermarket support other than generic or universal stuff is slim
Fortunately, wheels are often universal/generic
Stock is:
  • 15" x 6"
  • 4 x 100 mm bolt pattern
  • 50 mm offset
  • 57.1 mm hub bore
These are on sale for $90 each and weigh in at 14 lbs. If still avaialble when I am ready to buy, might go with these
https://www.tirerack.com/wheels/Whee...7&autoModClar=
I'd considered the Trofeo for the future, $116 and 14.3 lbs
Old 11-18-2017, 04:06 PM   #3
If your SC2 has steel wheels, they're not factory-stock. SC2's only ever had alloy wheels from the factory. Specifically for '97, it's #6 here: http://evilplastic.com/wheels.htm
Any of those will fit on any S-Series (along with the various 14" steel wheel options), without issue, unless there's something wrong with the suspension geometry (everything from rust built up on the hub to bent strut/control arm/knuckle).
As for aftermarket wheels, I've always wanted a set of these Eniki WDM wheels.
For the 4-5 lug conversion, the 2nd Cavalier probably has the closest hub/bearing size's to the S-Series. The rear's looked like they'd be close to bolt-on swap which means you could potentially get just the front hub from one and put it on the SC2 in place of the 4-lug hub.
Old 11-18-2017, 05:52 PM   #4
Jonasan308
Jonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of light
Jonasan308's Avatar
1999 SC1
With wheels that light, is denting them a big concern? I thought about how they would look on my car but i dont wanna damage them because of potholes. My city is infamous for its crap roads and i feel like id be having serious issues with damage.
1999 Saturn SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-182k currently (May 2018)
Dodging potholes should be a sport
Add to Jonasan308's Reputation
Rate the quality of this post and help Jonasan308 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonasan308 is offline   Reply With Quote
Old 11-20-2017, 09:06 AM   #5
Is that true for all years?
My '02 had steel wheels with these plastic covers when I got the car and I've seen them on many 3rd gen coupes (I'm 2nd owner, I think, and I don't think the PO is the type that would go from alloys to steel)
Old 11-20-2017, 10:16 AM   #6
Not sure if it's true for 3rd gen. Could be like the body color mirror drop they did starting in '97.
The OP has a '97 which came with alloys from the factory, no matter what has been put on it now
Old 11-20-2017, 11:36 AM   #7
yes, my '97 SC2 has those same wheels. I like the looks of those.
Not keen on the steel wheels on my '02 but good enough for now. The red coupe is a spittin' image of my car (and probably a thousand others ), except I have a white pinstripe under the molded arch along the body and dark rear tint
I don't think I could go 17" like your link . . . like jonasan points out, my state is pretty well known for its killer potholes. I'd stick with 15" up here, might go 16" if I moved a little south.
Aftermarket Wheels Meum92 L-Series Tech 7 01-01-2013 06:50 PM
aftermarket 18 or 20 wheels ? blockrockin 2008 Vue 4 01-10-2008 01:30 PM
aftermarket wheels on 08 vue mjmi11er Vue Mods 0 08-26-2007 08:01 AM
Aftermarket wheels for my 04 V6 Patrick_97SC2 Vue General 4 08-19-2004 06:33 PM
Looking for ideas for a tasteful spoiler sketchout Mods and Performance 4 09-12-2002 08:22 PM
