Old 11-17-2017, 12:10 PM   #1
RJ Isaac
RJ Isaac is on a distinguished road
Default Replacing the rear exrerior door handle pivot.
The rear passanger door handle pivot of my 07 ION broke and must be replaced. I removed the exterior skin and just need to remove the pivot itself. However, it looks as if it is mounted with rivets. How do I remove and replce the handle pivot?
Iíve attached a picture.
File Type: jpeg EEBE80A3-B64D-411D-A9E1-E120851FC915.jpeg (113.0 KB, 5 views)
Add to RJ Isaac's Reputation
Rate the quality of this post and help RJ Isaac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RJ Isaac is offline   Reply With Quote
Old 12-18-2017, 09:47 PM   #2
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Default Re: Replacing the rear exrerior door handle pivot.
Any luck. I think thise exterior plastic rivots that hold the door handle on are not available anymore.
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddemier7 is offline   Reply With Quote
Old 12-19-2017, 12:31 AM   #3
From the service manual (for 2005, should be the same form yours).
Door Handle Pivot Replacement - Outside
Removal Procedure
Disconnect the latch release rod. Refer to Door Handle Rod Adjustment - Front Outside .
Remove the outer door panel. Refer to Outer Door Panel Replacement Front - Bolt On or to Outer Door Panel Replacement Rear - Bolt On .
Object Number: 867420 Size: SH
Click here for detailed picture of above image.
Remove the bracket from the door structure. Use a center punch to knock out the steel center of the rivet .
Use a 7 mm (ľ in) diameter drill bit to drill out the rivet.
Slide the pivot bracket, with the latch release rod, down and out. Remove the pivot bracket from the door.
Installation Procedure
Install the pivot assembly into the door structure.
Install the rivets into the bracket and door structure.
Connect the latch release rod. Refer to Door Handle Rod Adjustment - Front Outside .
Install the outer door panel. Refer to Outer Door Panel Replacement Front - Bolt On or to Outer Door Panel Replacement Rear - Bolt On .
Add to ssicarman's Reputation
Old 12-19-2017, 10:36 PM   #4
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Im talking about the little plastic clip that holds the exterior door handle in place. I couldn't find a replacement so I left it alone.
Handle Pivot MiSaturn S-Series Tech 1 07-31-2013 07:40 PM
Rear inner door handle replacement bo130 S-Series General 6 04-07-2013 12:00 AM
Replacing a Door Handle on my 2008 Vue mremeto 2008 Vue 3 01-29-2012 08:24 PM
LW1 2000 rear door handle removal bigcougar L-Series General 2 06-09-2011 09:42 PM
rear door handle carolb4 S-Series Tech 3 01-05-2007 10:39 PM
