Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 11-14-2017, 02:05 PM   #1
BobWolf
BobWolf will become famous soon enough
Default Depris in oilpan. What is it?
2.2 Ecotec Ion rebuild.
So far so good with the inframe rebuild.
Head stripped, cleaned, and checked. Getting ready for a valve job for what its worth polished the chambers. I removed the pistons, cleaned, baked, high temp ceramic coated the crowns, phosphate dryfilm coated the skirts. New Mahle standard rings gap at the middle of specs bores needed very little correction just a quick pass with a hone. rod bearings were good, journals look good, crank play is in spec. So far, the rebuild has been unremarkable
I removed the oil pan to reinstall the pistons and I opted to remove the windage tray and clean the oil pan and inspect the oil pickup tube, at this point I found the remains of what appears to be old timing chain guides, this along with other minor damage indicates timing chain failure at some point.
I found pieces of some kind of ring stuck under the oil pickup.
It measures about 1/8 inch thick and about 1 1/4 inch in diameter and almost fits the diameter of the snout on the main pulley and inside the the oil pump gear. one piece was blackish blue so it got very hot before failing.
Looking around inside the crank case Im not finding any signs of parts that failed under force so this has me puzzled.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Old 12-06-2017, 11:46 AM   #2
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Default Re: Depris in oilpan. What is it?
I have some oil slude build up. How hard is it to take the head off and cams out and have cleaned to remove sludge? Is it even worth it?
Would you reccomend just taking the valve cover off and vacuming sludge out? Or not even mess with it. Its a 2.2 ecotec with 218,000 miles but runs great!
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddemier7 is offline   Reply With Quote
Old 12-06-2017, 01:59 PM   #3
hoosierrun
hoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nicehoosierrun is just really nice
2006 VUE 2.2L
May be best not to mess with it. Loose stuff breaking off will drop down the oil galley passageways and small stuff might get picked up (or clog) the pickup screen, get caught in the oil pump gears, or potentially clog the oil filter.
With as much mileage and how good running it is... I don't think you can make it much better, and there is the potential to create problems.
John.... 2006 Saturn Vue, 2.2, 186,000 miles Recently junked out - (threw a rod)
Add to hoosierrun's Reputation
Rate the quality of this post and help hoosierrun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoosierrun is offline   Reply With Quote
Old 06-08-2018, 06:58 AM   #4
reginalawson
reginalawson is on a distinguished road
I believe that you were able to resolve your issue in a professional way! To be honest, I don't think you can make it much better, and there is the intention to create problems.
http://resume-writer.net/blog/order-professional-cv-and-cover-letter-writing-service-here
Add to reginalawson's Reputation
Rate the quality of this post and help reginalawson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
reginalawson is offline   Reply With Quote
Old 06-28-2018, 01:12 AM   #5
Alexferguson
Alexferguson is on a distinguished road
say good shape, near mint interior, does have boost gauge, fog lights, etc.
Add to Alexferguson's Reputation
Rate the quality of this post and help Alexferguson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alexferguson is offline   Reply With Quote
Debris in oilpan. What is it? BobWolf Vue General 3 11-18-2017 11:03 PM
VIDEOS: Patching a rusted subframe & refinishing a rusted oilpan junker S-Series Tech 1 07-01-2012 02:22 PM
Oilpan Removal: 2001 l200 wagon (2.2l ecotec) SumoRerun L-Series Tech 0 01-08-2012 07:26 PM
Hole in oilpan Wallace L-Series Tech 11 10-11-2002 12:32 PM
