Old 11-14-2017, 02:04 PM   #1
BobWolf
BobWolf will become famous soon enough
Default Debris in oilpan. What is it?
2.2 Ecotec Ion rebuild.
So far so good with the inframe rebuild.
Head stripped, cleaned, and checked. Getting ready for a valve job for what its worth polished the chambers. I removed the pistons, cleaned, baked, high temp ceramic coated the crowns, phosphate dryfilm coated the skirts. New Mahle standard rings gap at the middle of specs bores needed very little correction just a quick pass with a hone. rod bearings were good, journals look good, crank play is in spec. So far, the rebuild has been unremarkable
I removed the oil pan to reinstall the pistons and I opted to remove the windage tray and clean the oil pan and inspect the oil pickup tube, at this point I found the remains of what appears to be old timing chain guides, this along with other minor damage indicates timing chain failure at some point.
I found pieces of some kind of ring stuck under the oil pickup.
It measures about 1/8 inch thick and about 1 1/4 inch in diameter and almost fits the diameter of the snout on the main pulley and inside the the oil pump gear. one piece was blackish blue so it got very hot before failing.
Looking around inside the crank case Im not finding any signs of parts that failed under force so this has me puzzled.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Old 11-14-2017, 03:32 PM   #2
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Default Re: Debris in oilpan. What is it?
Perhaps the engine had a catastrophic chain failure and or water pump) and no one went in and cleaned it out after a repair or perhaps you have WAY more trouble than you thought
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Old 11-14-2017, 03:43 PM   #3
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
can you post a photo?
Add to waiter21's Reputation
waiter21 is online now   Reply With Quote
Old 11-18-2017, 11:03 PM   #4
BobWolf
Default Re: Debris in oilpan. UPDATE
Update.
Man I hate it when people do hack job repairs, maybe its because I took Aviation mechanics and always had zero tolerance for halfazed workmanship.
Anyway, I started removing the timing chains the cam set looks like a cheap aftermarket garbage knockoff kit.
The balance shaft gears are OEM and the exhaust and intake balance shaft gear covers were beat up and appears to be missing a spacer that is close to what was left of the metal ring I found in the oil pan. Speaking of witch I'm glad I was able to remove the pickup tube as it too was jammed full of pieces of plastic chain guides. Surprisingly the engine bearings seem to be in reasonable shape with very little play and still in specs.
Benjamin Franklin.
What is it? Debris in oil pan. BobWolf Ion Tech 0 11-13-2017 09:19 PM
Debris on radiator RobertGary1 S-Series Tech 4 11-14-2016 07:26 PM
Oilpan Removal: 2001 l200 wagon (2.2l ecotec) SumoRerun L-Series Tech 0 01-08-2012 07:26 PM
Debris in CD player Maritime Storm Ion Tech 6 07-05-2007 04:56 AM
Hole in oilpan Wallace L-Series Tech 11 10-11-2002 12:32 PM
