Old 11-14-2017, 10:48 AM   #1
datlas
datlas is on a distinguished road
Default Click from Clutch - Any Ideas?
My 1998 SL has obviously a personality. It has a new sound which has just started the past few days.
As soon as I let up on the clutch pedal, there is a click/snap. It sounds like it is coming from near the pedal (ie. inside the car) The feel of the clutch and engagement and everything else works FINE so I am not highly concerned. But it is a new sound.
Any ideas or thoughts?
Add to datlas's Reputation
Rate the quality of this post and help datlas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
datlas is offline   Reply With Quote
Old 11-14-2017, 12:03 PM   #2
Default Re: Click from Clutch - Any Ideas?
The clip that holds the clutch master rod (goes through the firewall) to the clutch pedal? I'm gonna find a pic, BRB
edit: This one, follow the clutch "arm" upwards. Might be loose, or may just need lubing. It's the same clip used on the manual transmission tower under the hood to hold the cables on
Old 11-14-2017, 12:41 PM   #3
datlas
Thanks, I will take a look.
Old 11-14-2017, 10:31 PM   #4
uccoskun
uccoskun is on a distinguished road
there is a swith at thebottom. neutral switch, will make similar sound.
Add to uccoskun's Reputation
Rate the quality of this post and help uccoskun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
uccoskun is offline   Reply With Quote
Click click no start for you - How do I tell if it's starter, alternator, or ??? jvarnes S-Series Tech 6 04-25-2015 01:16 PM
Clutch Exploded? Need Ideas (Pictures Included) Macgyver S-Series Tech 3 12-19-2013 11:59 AM
well i got a new problem named click-click- click-click- click-click- click sl2solow S-Series General 3 08-13-2010 09:49 PM
Clutch pedal click,& keyless entry disconnected/ auxmike S-Series Tech 3 01-05-2003 12:29 AM
