Old 11-14-2017, 09:13 AM   #1
Driftfan13
Driftfan13 is on a distinguished road
Default No power at all! Please help!
So, I wrecked my 2001 sl1 a while back. It ended up with a bent front sway bar, bent rim and possibly buckled the subframe slightly. Being that it also had engine issues we bought a whole other car to use for parts. The parts car is a 1998 sl2. I swapped over the sway bar and subframe and decided to take the motor and trans too. Being the engine and wiring difference I went ahead and swapped everything to avoid splicing together my own harness. I swapped the engine harness, body harness, pcm (no longer have the bcm), instrument cluster, both fuse panels and dash board. Everything seems to be connected the way it should but when I connect the battery I have no power to a lot of fuses. I suspect that I have a bad/ missing ground but I canít seem to figure it out. Does anybody have and advice?
Add to Driftfan13's Reputation
Rate the quality of this post and help Driftfan13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Driftfan13 is offline   Reply With Quote
Old 11-15-2017, 06:38 PM   #2
Default Re: No power at all! Please help!
Another FrankenSaturn in the making except this one's not yet alive? Descriptions seem complete but there are some fine points needed to understand few things separating your '01 gen-3/bcm/Passlock and '98 gen-2 starter interrupt circuit. This is besides your main power issues.
When transferring the '98 wiring harness, did you overlook all the various grounds to electrical and electronics? Ground connections are all over the place. Main ground is between battery and two connections - battery negative to chassis and engine block. Battery positive is between main/secondary fuse panels and starter terminal.
Old 11-18-2017, 08:56 PM   #3
Driftfan13
Yes, the battery cables are hooked up correctly. I wanted to avoid having any electrical issues, so I swapped all electrical components. All of the wiring harnesses and almost everything that plugs in to them. I have also downloaded manuals, searched the forums, etc. to make sure all my ground wires and splice packs are accounted for and in the right spots.
Old 11-18-2017, 09:48 PM   #4
Electrical stuff is fun, in that just because it's got a great MECHANICAL connection doesn't mean it has _any_ ELECTRICAL connection.
Which fuse's don't have power? Not all have power all the time, some only in "key-on" and others only when the PCM or some button activates them.
Power door locks,power window,fan for heat don't work dddaaa S-Series Tech 1 08-11-2011 10:40 AM
Where to get ignition switched power for two axuiliary power outlets PlasticCarsRock S-Series Tech 10 05-04-2010 02:26 PM
How Difficult to Install Power Windows on a car with Power Locks? sandybright S-Series Tech 1 09-07-2006 03:25 PM
Power lock, power mirrors, and dome light not working. eng23ine S-Series Tech 3 10-28-2004 05:58 AM
95SL2 Power locks and 12V power stopped working skijay S-Series General 5 04-13-2004 08:36 PM
