Old 11-13-2017, 09:19 PM   #1
BobWolf
BobWolf will become famous soon enough
Default What is it? Debris in oil pan.
So far so good with the inframe rebuild.
Head stripped, cleaned, and checked. Getting ready for a valve job for what its worth polished the chambers. I removed the pistons, cleaned, baked, high temp ceramic coated the crowns, phosphate dryfilm coated the skirts. New Mahle standard rings gap at the middle of specs bores needed very little correction just a quick pass with a hone. rod bearings were good, journals look good, crank play is in spec. So far, the rebuild has been unremarkable
I removed the oil pan to reinstall the pistons and I opted to remove the windage tray and clean the oil pan and inspect the oil pickup tube, at this point I found the remains of what appears to be old timing chain guides, this along with other minor damage indicates timing chain failure at some point.
I found pieces of some kind of ring stuck under the oil pickup.
It measures about 1/8 inch thick and about 1 1/4 inch in diameter and almost fits the diameter of the snout on the main pulley and inside the the oil pump gear. one piece was blackish blue so it got very hot before failing.
Looking around inside the crank case Im not finding any signs of parts that failed under force so this has me puzzled.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
Debris on radiator RobertGary1 S-Series Tech 4 11-14-2016 07:26 PM
L81 Debris Tray? CA-Legal-Vette Vue General 5 09-09-2014 11:55 PM
Oil with debris in it - use or discard curls S-Series General 2 05-23-2010 03:23 PM
Debris - Overhead Lights cfisher2 Aura General 11 04-16-2009 11:25 PM
Debris in CD player Maritime Storm Ion Tech 6 07-05-2007 04:56 AM
