Old 11-13-2017, 08:55 PM   #1
RICH1959
RICH1959 is on a distinguished road
Default Transmission swap
I have a 1999 sw2 automatic will a 1995 sl2 transmission fit and work correctley
Add to RICH1959's Reputation
Rate the quality of this post and help RICH1959 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RICH1959 is offline   Reply With Quote
Old 11-13-2017, 11:35 PM   #2
billr
Default Re: Transmission swap
A '95 auto trans? Yes, that should go into the '99 fine.
Add to billr's Reputation
Old 11-14-2017, 12:13 AM   #3
Jonasan308
Jonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of light
Jonasan308's Avatar
1999 SC1
Just so you will know next time, you dont need to post the same question in multiple places, here was fine just once.
1999 Saturn SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-178k currently (jan 2018)
Dodging potholes should be a sport
Add to Jonasan308's Reputation
Rate the quality of this post and help Jonasan308 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonasan308 is offline   Reply With Quote
Old 11-14-2017, 08:12 AM   #4
RICH1959
Ok i will next time , but thanks for the info was there any up dates on the later automatic transmissions or are the 95 & 99 units the same ?
Old 11-14-2017, 11:26 AM   #5
billr
I believe they are identical. I have a '97 TAAT in a '95 car (DOHC).
Old 11-14-2017, 11:52 AM   #6
They are not identical. Look at the gear ratio chart I linked. The 95 will function correctly if it is in good mechanical shape in your 99.
Old 11-14-2017, 12:21 PM   #7
billr
Oops, I forgot there were those slight ratio changes in the later years! That link is in the OP's duplicate thread? What forum is that in? I want to refresh my memory...
Old 11-14-2017, 07:10 PM   #8
RICH1959
Will you notice the differance in driveability with the differant gear ratio
Old 11-14-2017, 09:08 PM   #9
billr
Ha, I'll try again. I'm guessing the ratio differences are too slight for you to notice if the PCM won't set a "wrong gear ratio" code.
Old 11-14-2017, 09:44 PM   #10
The final drive ratio is not a concern but reverse is and as long as you do not drive over 15mph or so then it will not be noticed. Reverse has a higher ratio in the 95.
Old 11-14-2017, 10:22 PM   #11
RICH1959
I am gussing you meen 15 mph in rev
Old 11-14-2017, 11:07 PM   #12
Yes, at somewhere in that speed range or above the TCU will detect the gear mismatch after a time delay from what is programmed as SLIP and get all excited and start setting codes and disabling things. Don't think anyone has actually tested it out though.
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 04:01 PM
ION Transmission swap for vue with Vti? kim_lombard Vue General 2 07-11-2009 10:08 AM
ION 2 transmission swap mikkel Ion Tech 1 09-15-2007 08:18 AM
Transmission Swap Speedy15 S-Series Mods 8 03-13-2006 10:39 PM
transmission swap trlla91sl2 Miscellaneous Tech 0 02-04-2002 06:40 PM
