Old 11-13-2017, 02:53 PM   #1
GONZOTOM
GONZOTOM has a spectacular aura aboutGONZOTOM has a spectacular aura aboutGONZOTOM has a spectacular aura about
2005 VUE 2.4L
Default 2002 wont blow heat on the floor
My heater had been working fine, but now today it wont switch from the vent or defrost to the floor.
If I have it on defrost it blows out there but also out the vent which it shouldn't be. Then when I switch it to the floor I can hear it move but it just blows out the vent and not on the floor.
So its always blowing out the vent where ever I have the selector.
Any ideas?
Add to GONZOTOM's Reputation
Rate the quality of this post and help GONZOTOM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GONZOTOM is offline   Reply With Quote
Old 11-13-2017, 07:34 PM   #2
GONZOTOM
2005 VUE 2.4L
Default Re: 2002 wont blow heat on the floor
Just had to thank you guys here that know our Saturns! Another problem solved here. I found this through the search function and it worked like a charm. I am no car repair guy but am really appreciative of the help you folks provide!!!
Thanks again and here is what I found:
Re: '04 Vue heat problems (no feet heat)
Originally Posted by PatrickMcD View Post
Hello -- new to the forum
My 2004 Vue is having it's first problem, when I turn the heat on only the cabin heat works. If I put it on feet it doesn't blow any heat to the floor...any ideas where to start? Thanks!
You could try running HVAC control through calibration mode to see if the mode door motor is out of sync w/ the control head.
With key ON ... calibrate mode door by simultaneously pushing the A/C and RECIRC buttons on HVAC control module three times each, within two seconds of initial push.
• The A/C and RECIRC button LED's will flash while this calibration is taking place.
• The calibration will take anywhere between 10 to 30 seconds depending on battery voltage.
• The LED's will quit flashing when the calibration is complete.
Cycle ignition and check for improvement.
Old 11-27-2017, 07:30 AM   #3
cjhsa
cjhsa is a jewel in the roughcjhsa is a jewel in the roughcjhsa is a jewel in the rough
I'm glad this worked for you. It did not work for me. I can only get heat from the floor vents if I select the floor or between floor and full defrost. Any setting partially between floor and dash vents results in heat only coming from the dash, and your feet get cold. Also, setting to "floor" results in cycling of the A/C compressor which is part of the defrost setting.
2007 VUE AWD V6 3.5L
Add to cjhsa's Reputation
Rate the quality of this post and help cjhsa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cjhsa is offline   Reply With Quote
Floor heat vents no worky. DavidBo Vue Tech 6 01-15-2015 02:27 PM
1995 Saturn SL2 A/C and heat blower wont work mikebu S-Series General 2 01-14-2014 01:33 AM
97 Saturn SL2 interior fan to blow heat not working paumcd S-Series Tech 1 11-05-2011 02:07 PM
2002 Vue Vent Won't Blow on Floor mohremail Vue General 6 04-13-2009 08:04 AM
A/C wont blow texwashere Vue General 2 08-06-2008 12:51 PM
