Old 11-09-2017, 05:59 PM   #1
Thruxtonup
Thruxtonup has a spectacular aura aboutThruxtonup has a spectacular aura aboutThruxtonup has a spectacular aura about
2002 SL1
Default 02 sl1 heat isn't working
Hey all, just recently found the forum.
I have an auto 02 sl1 with 105xxx miles.
I've ran into a strange issue where, it's throwing a constant coolant temp light, no matter where the temp gauge is and will only blow warmish air on the lowest fan setting. Any higher and the air is pretty much the ambient temperature.
Any insight is appreciated!
Add to Thruxtonup's Reputation
Rate the quality of this post and help Thruxtonup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thruxtonup is offline   Reply With Quote
Old 11-09-2017, 06:37 PM   #2
Chrisohki
Chrisohki is on a distinguished road
Default Re: 02 sl1 heat isn't working
Have you checked your coolant level yet?
Add to Chrisohki's Reputation
Rate the quality of this post and help Chrisohki reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chrisohki is offline   Reply With Quote
Old 11-09-2017, 06:38 PM   #3
Thruxtonup
2002 SL1
Yes. Completely full
Old 11-09-2017, 07:29 PM   #4
Chrisohki
Could be the thermostat stuck in open position.
How hot does the gauge get after rubbing for 15/20 mins?
Old 11-09-2017, 07:42 PM   #5
Thruxtonup
2002 SL1
Usually hangs on between 1/4 And 1/2
Old 11-09-2017, 08:13 PM   #6
You may be describing two issues; lack of heat and an errant coolant indicator. If the engine isn't overheating, the coolant indicator may be telling you coolant level is low. Even when coolant level is correct, old cooling systems create slime and other undesirables. I not flushed out and replacing antifreeze, sludge may collect on the float, dropping it lower by weight and triggering the coolant light. A quick test of this is to overfill the container above the fill line by about an inch and see if the light turns off. If it does, the coolant container can be cleaned with hot water and dishwashing powder to remove sludge on the float. Or just overfill and leave it at that. The lack of heat may be related to one of several things; blocked heater core, heater hoses, outlet tube or worn out t-stat. If periodic coolant flushing and replacement isn't done, do so and disconnect the heater hoses to force water into the heater core to flush out any blockage, reversing flow to ensure flow.
Old 11-11-2017, 12:20 AM   #7
T. Thudpucker
T. Thudpucker is on a distinguished road
I'll cast my vote for blocked heater core.
#1 1999 SL2, RIP
#2 1999 SL2, Operational
#3 1999 SL2 HCE, Operational
#4 2001 SL1, Operational
#5 2001 SL2 10th Anniversary, stored *NEXT*
#6 1997 SL2, Operational
1979 Dodge Adventurer 200
Add to T. Thudpucker's Reputation
Rate the quality of this post and help T. Thudpucker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
T. Thudpucker is offline   Reply With Quote
Old 11-11-2017, 07:21 AM   #8
trottida
trottida's Avatar
The SOHC engine doesn't create much heat to begin with even at full operating temperatures.
The first problem regarding the low coolant is likely a stuck float switch in the coolant reservoir as fdryer noted.
The second issue could be a few things...
  • A bad ETCS which are cheap and easy to replace.
  • A failed thermostat which again are cheap but a bit more involved to replace.
  • A blocked heater core which sometimes you can back flush to resolve.
  • The HVAC temp controls could be failing (not likely).
If you've never changed the thermostat I'd probably start there and while you have the coolant drained I would back flush the heater core and clean up that reservoir. It wouldn't hurt to change the ETCS even though in the 2002 models they installed the brass tipped version which don't crack like the resin tipped versions installed prior to 2002.
Edit: I just noticed that you wrote "Coolant Temp Light". We both assumed low coolant light. Which one of the two shown below are you referring to? The temp gauge and the coolant temp warning light would both be controlled by the ECTS. Try changing this first.
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Old 11-11-2017, 07:49 AM   #9
trottida
trottida's Avatar
Also, the temp gauge should read as the gauge below (~1/3) if your ETCS and thermostat are working properly. If fully warmed and it hangs at 1/4 it is likely you have a leaking thermostat which is not allowing the engine to come up to temperature and thus not providing sufficient heat to the heater core.
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Old 11-16-2017, 03:29 PM   #10
Thruxtonup
2002 SL1
I'm sitting in it right now, the coolant is up to temp but it's not blowing any warm air at all. So I'm going to wager it's the core. I'll try to back flush it tomorrow
Old 11-16-2017, 03:55 PM   #11
Two more possibilities are the blend door and the temperature slider.
The temp slider has a cone shaped arm at the other end that a wire loop cable end to the blend door hooks onto. I was getting no heat in the cabin because the previous owner disconnected it for some unknown reason (when installing a stereo?). If you are the original owner, or the heat worked before but stopped, this is probably not the issue - the cone has a groove that the end loop locks into and is unlikely to slip out.
The cable moves a blend door which controls how much heated air enters the cabin. occasionally, the gear or something breaks and the door does not move.
With the light, assuming it's the Engine Temp Light (on solid, not blinking) and not Low Coolant, I believe it can trigger if there is a fault or temperature mismatch with the automatic transmission coolant temperature sensor, located at the top of the trans. I don't have an owner's manual handy or an auto trans- maybe someone can confirm.
edit: to take a look behind the radio, I followed this, skipped all the steps noted, but also skipped the second step (column filler panel)
http://www.differentracing.com/tech_...0-02radio.html
You may be able to check the core for blockage by checking temp of the inlet and outlet hoses. Of course, if your coolant is old or unknown age, may as well flush the crap out of everything
Old 11-16-2017, 05:38 PM   #12
RobertGary1
I had a heat issue that was caused by an anchor on the sleeve for the heat control breaking free and allowing excessive flex on the sleeve. As a result I lost about 75% of cable movement. The attach point is just to the right of the driver's right leg. Just remove the panel and make sure the cable sleeve is still attached to the air box and not moving around when you move the heat control.
-Robert
Old 11-16-2017, 06:56 PM   #13
Waiex191
Waiex191's Avatar
I have no contribution, but a heat related question. The floor heat on my SL2 has been weak since new. Is this typical? My old 83 Omni was junk, but the heat on the feet was awesome.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-20-2017, 08:45 PM   #14
Thruxtonup
2002 SL1
I finally had time to flush the core today, and success! I have heat.
Thanks everyone
2003 Vue AC/Heat mixer not working driveguy Vue Tech 1 06-13-2013 08:05 PM
97 Saturn SL2 interior fan to blow heat not working paumcd S-Series Tech 1 11-05-2011 02:07 PM
Heat Not Working In 96 SC1 SickSc1 S-Series Tech 3 12-07-2009 09:42 PM
A/C not working and get low humming noise when turning on the heat. jc123 L-Series General 2 04-12-2006 01:28 PM
2001 L300 AC/Heat Fan Not Working NoDents L-Series General 6 10-25-2005 09:04 AM
