Old 11-09-2017, 05:30 PM   #1
chip707
chip707 is on a distinguished road
Default Dashboard lifting fix?
I own a 2002 Saturn SL2. My OCD of how the dashboard is lifting away from the speed odometer. Is there anyway to fix this on the dashboard? It seems like it's not flush and I wish it was to give it a sleek and clean look.
Thanks
Add to chip707's Reputation
Rate the quality of this post and help chip707 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chip707 is offline   Reply With Quote
Old 11-09-2017, 06:02 PM   #2
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Re: Dashboard lifting fix?
Glad I'm not the only one bothered by this.
I took the dash cover off my SC to do some other work and reinstalled it very carefully. This cut the gap by 2/3s, but still left 1/3 to annoy me.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 11-09-2017, 06:47 PM   #3
Broken tabs? Loss of the metal inserts that hold the tabs? Is it heat warped? The fix depends on what is causing it.
Old 11-09-2017, 06:56 PM   #4
floridasl22002
The same has happened on my son's 2002 SL2. It's just bad design and nickle & diming. The tab on the dash cowl is supposed to be held in place in the indents on the soft padded dash top. That's the theory. The reality it is doens't work as the soft dash top loses shape slightly over the years and there is absolutely that will grip the two together. The only fix I can think of is devising some sort of self tapper from the cowl to the dash top. Check most other dash tops and they use fasteners. I have a Suburban and it uses hex screws. my other son has a 2003 L300 and it uses philips screws. The S series uses fresh air!
Old 11-09-2017, 07:30 PM   #5
toggenburg
toggenburg's Avatar
Is the dash really redone with a metallic flake paint, or are those speckles just because of the camera flash?
It would look great if it were the entire dash.
Old 11-09-2017, 10:27 PM   #6
chip707
Yeah it has sparkle, to match the speed odometer. I had the some guy paint it for 100 bucks. I seen some YouTube guy do it and I like the look. The speed odometer is from an ls and it goes nice with the look.
Old 11-09-2017, 10:31 PM   #7
chip707
I don't remember it having metal tabs. Is there suppose to be metal tabs? Im not the original owner I pick up this car all beat up and I like my things as nice as can be. So I've been polishing her up. The dash board sucks, I order a rubber strip piece to put in between the window and dashboard hopefully to bring that gal closer. But if there metal tabs that I'm missing does anyone know the model or item number for it so I can put it back. Cuz it just looks tacky just with that gab especially with that nice bezel painted
Old 11-09-2017, 11:02 PM   #8
chip707
I'm looking at other people post some are saying there dispose to be some kind of glue adhesive that went on the tabs and to get it back that way you have to glue it.... not sure if that's the case
Old 11-09-2017, 11:40 PM   #9
The plastic tabs on the cover seat into slots that have a metal insert which grabs the tabs. These tend to pull out with the tab and end up in the trash. look at the tabs-slots on the flat right hand side. If you see the inserts then it is off to the P&P to collect replacements.
Old 11-10-2017, 07:51 AM   #10
trottida
trottida's Avatar
I'd like to see a photo of it zoomed out if you don't mind.
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 11-10-2017, 03:04 PM   #11
chip707
Old 11-10-2017, 03:11 PM   #12
chip707
The flat hand side is you talk about is where the screws are at?or you talking about underneath the dash that connects to the bezel that should have the slots. I'm going to take picture of underneath my dash and bezel . I'm also intrigue to see what these clips look like
Old 11-10-2017, 03:43 PM   #13
trottida
trottida's Avatar
Here is the drawing from the FSM showing the clip locations.
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Old 11-10-2017, 03:46 PM   #14
The part you are looking for is the one with the numbers 2 and 5 next to it. You want the single part #5 and you should have 7 of them across the top of the dash. There are matching plastic tabs on the dash cover, usually several are snapped off. The part number for the #5 is 21035019. If the tabs are snapped off then this is the repair part and usually you have to remove the #5 to use these, 21040288. This is a possible source, https://www.partsvoice.com/
Drawing also covers the 02 models.
Old 11-10-2017, 04:03 PM   #15
saturnsctwo
mine is like this also. all my tabs are perfect. it's just heat warped a little... not much you can do with it. the sides next to the winshield pillar molding were lifting also, but those areas I was able to re-glue them back down. they look better.....
Old 11-10-2017, 06:39 PM   #16
toggenburg
toggenburg's Avatar
Say chip707, ... I don't know where you are in the USA, but OldNuc's part numbers on that website shows 15 places have anywhere from 1 to 10 of them.
Actually, they don't have the original ...19 part number, just the ...288 repair part ONLY.
https://www.partsvoice.com/partsearch
If all else fails, maybe try gluing a set of velcro patches there.
Old 11-11-2017, 12:49 AM   #17
chip707
http://img.photobucket.com/albums/v6...60ECDE6BFD.jpg
Old 11-11-2017, 12:54 AM   #18
chip707
Old 11-11-2017, 12:57 AM   #19
chip707
I took off the dash board noticed nothing was missing all clips seem to be present. Don't know if the part is warp or that's just how it is... you can see the picture where it has the groove for the tab, but it seems like there should be something there. Maybe I'm missing something I don't have a clue since I never seen what it's supposed to look like .
Old 11-11-2017, 09:02 AM   #20
PHOTOBUCKET will NOT allow 3rd party hosting of pictures without $$$. No one can see what you have. Use imgur.com for the free hosting.
All of the band-aids to bypass the PHOTOBUCKET money grab fail routinely.
Lifting my 99 SL yellowxj S-Series Mods 8 10-05-2010 08:36 PM
Lowering & Lifting? Bismarck318 Vue Mods 6 10-29-2009 10:26 AM
lifting 04 Rl help!? randypey Vue Mods 6 08-27-2008 10:33 AM
Radiator Cap Lifting egadz S-Series Tech 23 01-15-2004 12:55 AM
Lifting car plumsl2 Mods and Performance 5 03-26-2003 03:10 PM
