Old 11-09-2017, 01:36 AM   #1
Edorian
Edorian is on a distinguished road
2002 SL1
Default Ion 2007 Accel Position Sensor
Hi all,
Does the 2007 Ion Accelerator Position Sensor assy. contain a spring?
It's part number (GM) 22706224. Also are there any adjustments or calibrations to be made after installation?
Thanks!
Add to Edorian's Reputation
Rate the quality of this post and help Edorian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Edorian is offline   Reply With Quote
Old 11-14-2017, 11:44 AM   #2
BobWolf
BobWolf will become famous soon enough
Default Re: Ion 2007 Accel Position Sensor
its not difficult its no different than testing the TPS operation .On a throttle cable type I confirm its position by testing its voltage output with a test meter. Typically its between 1 Volt idle/closed throttle and 5 volts wide open throttle / WOT.
Step 1. Start with a good multimeter find a good ground. you should have 12 volts constant off the positive terminal or known 12 volt source
Step 2. disconnect the TPS connector and turn the key to engine run position. You want power going to the sensor.
PAY ATTENTION IF YOU CROSS HOT WITH SIGNAL OR GROUND YOU CAN RUIN THE COMPUTER.
Step 3 With the multimeter grounded probe the connector to find supply voltage. Note the supply voltage as this will be what you want at WOT.
Only one wire should be hot max voltage others might have a slight voltage usually a couple tenths of a volt.
Step 4 Switch to Ohms and check for ground. Ground the meter, and probe the low/no voltage wires, the one that zeros out is ground and the other is signal.
Step 5. Turn off the ignition, plug in the TPS, and BACK PROBE the harness, do not splice into the wires you will create a short. Sewing needles and low voltage jumper wires with alligator clips work best for this if you don't have harness probes.
Step6. Turn on the ignition but don't start the vehicle. Typically the voltage should be 1 volt or less at idle/closed throttle and at WOT the maximm voltage you read on the voltage wire should be present within a couple tenths of a volt.
Test drive and if it drives right call it a win and enjoy your favorite beverage.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
Add to BobWolf's Reputation
Rate the quality of this post and help BobWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobWolf is offline   Reply With Quote
2007 ion crankshaft position sensor peggles0224 Ion General 4 01-01-2015 04:16 PM
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
cam position sensor briansc1 S-Series Tech 5 09-09-2008 11:54 PM
Cam Position Sensor??? WEGoat Miscellaneous Tech 5 12-18-2004 10:13 PM
Cam Position Sensor??? WEGoat General Saturn Discussion 1 12-18-2004 02:35 PM
