Old 11-06-2017, 11:36 AM   #1
cheap one
cheap one is on a distinguished road
Default catalytic converter for standard transmission
Have a 06 Ion 2 w/2.2 engine w/standard trans. My flex pipe is leaking so I am looking into having the whole cat pipe replaced. Problem is any aftemarket I find online for a reasonable price is listed for an automatic transmission and I have standard. OEMs are 3-4 times the price. Is there really a difference. I don't live in CA so there is not an emisssions concern.
Add to cheap one's Reputation
Rate the quality of this post and help cheap one reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cheap one is offline   Reply With Quote
Old 11-06-2017, 01:27 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: catalytic converter for standard transmission
Are you aware that the flex pipe can be replaced separately? You can buy a decent quality replacement flexpipe for under $50 from eBay or Amazon. An exhaust shop will need to cut the old one off and weld the new part on.
I wouldn't replace the cat con unless you have more than 200K miles on the car. Even then, I'd probably let it ride unless you know it's clogged.
2007 Chevy Equinox LT 177K miles
Add to ruley73's Reputation
Old 11-06-2017, 01:35 PM   #3
Did you search extensively online (rockauto, summit racing, magna flow, etc)? If GM made a car, discontinued or not, parts are available. Discontinued models requires manufacturers to have parts for at least ten years. You may not have searched enough but if you still cannot find any aftermarket exhaust system parts and don't want to buy OEM then you'll have to resort to custom making replacement parts from pieces to mate. This can be either welded by a muffler shop or specialty welders or bolted together. Your choice. Other members may have suggestions too. And there's always a non cat setup if your state doesn't require emissions inspections. The only problem with bypassing the catcon is the second O2 sensor needs to see exhaust to measure catcon efficiency in a system missing its catcon. This will generate an error code. At the least, a straight pipe will need a bung hole to mount the downstream sensor.
Old 11-07-2017, 05:42 PM   #4
cheap one
Thanks for reply - This may be the way I go even though I just turned over the 200k mark. This is the first car I bought brand new that hit 100k let alone 200k miles!
Old 11-07-2017, 06:09 PM   #5
cheap one
Thanks for ideas. I called Summit Racing and talked to Penelope (x-6862). Man, all service reps should be this good. I said I found one for an auto trans on their website, but not for a standard. She looked it up and said they didn't have one in their system. She then started looking at other brands and found that Magnaflow listed one, so she said she would contact them to see if they could supply Summit and then she would call me back with info.
She called the next day to tell me that Magnaflow hasn't developed that part yet, but she found another one from Davico and gave me the part number so I could order one from them.
Now, the new problem. When I looked up the Davico cat, it shows a pipe with 2 converters. I also looked it up from RockAuto and it shows the same thing. I crawled under my car and it only has one converter (and 1 O2 sensor). It really looks like the one for the auto transmission.
I think I might go with the idea of just welding on the replacement flex pipe.
-2006 Ion 2 Quad manual 5-speed, 200,030 miles
Catalytic converter and oil pan Adomka S-Series General 0 05-25-2014 07:26 PM
99 SC2, O2 sensor, catalytic converter, or transmission? CartesianLogic S-Series Tech 7 11-08-2013 01:55 PM
What causes a catalytic converter to go bad? zeissheadreggie Vue Red Line 3 08-28-2011 09:53 PM
Can I see anything in Catalytic Converter? Is it bad? flyhop S-Series Tech 6 07-29-2011 12:18 AM
Catalytic Converter SL2 in CA Whitedove S-Series Tech 9 05-29-2009 07:20 AM
