Old 10-30-2017, 08:55 AM   #1
flavecchia
flavecchia is on a distinguished road
Default TPMS Receiver location 08 Astra
I am trying to find the location of the the TPMS receiver on a 08 Astra. I looked it up on Alldata and it stated it is behind the glove box where the blower fan and resister are accessed and I have a known good one so I know whet it looks like, but can not find it. Can someone please tell me specifically where it is located?
Add to flavecchia's Reputation
Rate the quality of this post and help flavecchia reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flavecchia is offline   Reply With Quote
Old 11-08-2017, 09:49 AM   #2
flavecchia
Default Re: TPMS Receiver location 08 Astra
Really? 64 views and no one knows??
Old 11-08-2017, 11:56 AM   #3
If alldata is wrong, write them of the error. Did you try searching online and asking in other Astra forums?
Old 11-09-2017, 11:26 AM   #4
AstraFasta
AstraFasta will become famous soon enough
A Russian guy posted a few photos of receiver and location. I think the receiver is 12pin and photo #4 shows a 12 pin connector under the glove box between the blower fan & cabin air filter access door:
https://www.drive2.ru/l/476189690970505293/
Based on photo #4 and #5, I am reasonably certain both photos are from a right-hand drive car. Photo #4 looks like I recall my Saturn Astra H does. Photo #5 looks similar to the Saturn Astra, albeit more fancy than was sold in the US. The page is labeled Astra GTC and the subsequent Astra had a huge interior revamp.
__
If you don't see the connector there, it seems the UK connectors were behind the glovebox (which was on the left side of the car). So you might check above your brake pedal.
US system was mandatory so might be located in a differrent place (even with the same parts).
Add to AstraFasta's Reputation
Rate the quality of this post and help AstraFasta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-13-2017, 10:33 AM   #5
nicolas_p
nicolas_p will become famous soon enoughnicolas_p will become famous soon enough
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
As far as I know we don't use the same sensor in our Astras over here. GM NA must have moved it somewhere else because our system can't differentiate where the sensors are just that they are present and working.
Is there a reason why you need to find the receiver?
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Eibach Sportline, Whiteline BHR75Z swaybar and EBC Rotors
CD30 Mp3, Insignia jets, vxR surround, sharkfin antenna, Spoiler, Tint
Add to nicolas_p's Reputation
Rate the quality of this post and help nicolas_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nicolas_p is offline   Reply With Quote
Old 11-27-2017, 08:34 PM   #6
flavecchia
Because I cannot program the new TPMS sensors and the ting that I find odd, is the receiver is sold by high volume suppliers, Rock Auto Ebay ect but no one knows where it is located in the car.
Old 11-27-2017, 08:56 PM   #7
No one knows? Did you consider your local GM dealer or call GM support to see if GM can tell you exactly where its located? Dealer or GM support. One or both will have an answer. Another way other than asking members here is subscribing to alldata or Mitchell, both online. The last alternative is knowing someone working in either a repair or collision shop that has access to alldata or Mitchell and a favor in for return for beer, lunch, chocolate, whatever. Even a junk yard with a totaled '08 Astra may have someone know or you visit and poke around. And maybe some tire stores with tpms equipment may know..........
Old 11-30-2017, 06:21 PM   #8
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
The TPMS sensors on the astra don't need to be learned/matched to the car. Just put them on your wheel and that's it. The system will read the sensor levels once it autolearns the sensors (5km at a speed of 50km/h or more)
Old 03-11-2018, 04:39 PM   #9
rafaelarroyo
rafaelarroyo is on a distinguished road
When the warning light blinks, indicate TPMS malfunction, It is important to know where the receiver is at to verify connection or replacement, I have the same problem I cannot reset my TPMS sensors following the procedure, it must be the receiver not working.
Add to rafaelarroyo's Reputation
Rate the quality of this post and help rafaelarroyo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rafaelarroyo is offline   Reply With Quote
RKE receiver location on 01 SW beaverplt S-Series Tech 10 11-10-2013 09:58 AM
Location of XM receiver - 2009 VUE Hybrid propahac Vue Mods 0 06-09-2010 11:08 AM
Location of XM receiver - 2009 VUE Hybrid propahac Vue Tech 0 06-02-2010 10:06 AM
Astra TPMS amartin003 Astra General 13 10-04-2008 09:28 AM
RKE Receiver Location geeminator S-Series General 1 09-24-2005 05:34 PM
