Old 10-29-2017, 11:45 AM   #1
kevin_h
kevin_h is on a distinguished road
2007 VUE 2.2L
Default 2007 Vue - Cruise Control & Front Passenger Seat Issues
Hi,
New here. I recently purchased a 2007 Vue 2.2L FWD (105K) and have some questions / problems.
I searched through the Forum and could not find anything specific to help my issues.
Issue 1
The Front Passenger side seat will not recline. I believe I have the stock "dirty tan" fabric manual seats.
I pull up on the lever until it starts to bend. The lever goes up 2 inches but the locking mechanism does not release.
Does anyone have a parts diagram or directions on how to disassemble the passenger seat?
Issue 2
Cruise Control. The cruise control does not engage when I press the Set Button.
The Green LED in the On/Off button lites.
Does anyone have a trouble shooting guide for the Cruise Control and/or a wiring diagram?
Can anyone provide a link or source for a cheap copy of the Factory Service Manual?
Thanks for the help.
Cheers,
-Kevin
Add to kevin_h's Reputation
Rate the quality of this post and help kevin_h reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevin_h is offline   Reply With Quote
Old 10-29-2017, 02:01 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2007 Vue - Cruise Control & Front Passenger Seat Issues
Originally Posted by kevin_h View Post
Hi,
Issue 1
Issue 2
Cheers,
-Kevin
I can't help you with issue #1.
Regarding issue #2, does your Vue have an automatic or manual transmission?
Most likely, your cruise control release switch (located above the brake pedal) is either bad or out of adjustment. There are two switches on the brake pedal assembly.
The top one that has a two wire connector going to it is used for cruise control and TCC ([transmission] Torque Converter Clutch) control. The bottom one is used for BTSI (brake transmission shift interlock) and brake lights. It is also possible that the bottom switch is out of adjustment and holding the brake pedal assembly down just enough to open the circuit for the top switch. This would make the BCM think the brake pedal is being pressed all the time and not let the cruise control engage.
If you have a manual transmission, another possibility is that one of your clutch pedal switches may be bad or need to be adjusted.
2007 Chevy Equinox LT 177K miles
Add to ruley73's Reputation
Old 11-03-2017, 05:41 AM   #3
kevin_h
2007 VUE 2.2L
I have an automatic transmission. Thanks for the information.
I will check the two switches on the Brake Pedal.
The Brake lights are not on all the time.
Is this an indication that the Bottom Switch is working correctly?
Thanks,
-Kevin
Old 01-31-2018, 09:26 AM   #4
Saturn072014
Saturn072014 is on a distinguished road
Did you come up with a fix?
2009 XE 2.4 Saturn Vue.
Add to Saturn072014's Reputation
Rate the quality of this post and help Saturn072014 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn072014 is offline   Reply With Quote
Old 01-31-2018, 06:03 PM   #5
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
I have had both of those issues in my '03 and '04 Vues.
#1 was never fixable. Had to replace the seat.
#2 has happened three times between the two. Once was a bad sensor, once was a loose sensor, and the most recent was just due to a weak battery.
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
No front passenger seat richa Astra Tech 1 09-07-2016 07:27 PM
Speedometer/Cruise Control Issue, 2007 Vue 5spd chops Vue Tech 5 12-20-2013 06:18 PM
Front passenger seat hess Outlook General 1 04-21-2007 10:40 AM
Front passenger seat fix? NewCarNewbie Outlook General 0 02-03-2007 12:53 AM
Cruise Control Issues The Critic S-Series Tech 0 12-04-2006 09:48 PM
