Old 10-29-2017, 05:24 AM   #1
variable70
variable70 is on a distinguished road
2007 ION-3 Sedan
Default Can Someone explain this
07 ion3 2.2
Everyday on my ride home from work at the exact same spot, about 4 miles down the road, I get the "COOLANT" message displayed on my dash. Then about 2/10's of a mile down the road at the exact same spot it goes out. Been doing this about a week or so now. It happens on the downside of an overpass then goes off at the top of the next overpass. My plan next week is to take a different route home on Monday then normal route Tues.
Add to variable70's Reputation
Rate the quality of this post and help variable70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
variable70 is offline   Reply With Quote
Old 10-29-2017, 08:19 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Can Someone explain this
Your coolant level is just low enough to trigger the [low] coolant warning to come on during that particular part of your commute. Add some coolant and it will go away.
The coolant level needs to remain at or slightly above the large seam in the reservoir to prevent the coolant warning from being displayed.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 10-29-2017, 01:09 PM   #3
variable70
2007 ION-3 Sedan
Well, its at the seam. I guess I could add a little.
Old 10-30-2017, 10:43 PM   #4
bern
2004 ION-2 Sedan
The float inside the surge tank is loosing it buoyancy. It will get worse and the message will be on most of the time.
Replace the surge tank.
Add to bern's Reputation
Old 10-30-2017, 10:55 PM   #5
bern
2004 ION-2 Sedan
Old 11-13-2017, 04:39 PM   #6
variable70
2007 ION-3 Sedan
Well I added some coolant no change. It does come on more often now. I guess I will have to change tank. Is that just a fluid level warning or does it do anything else?
Can someone explain the ethanol to me... liquidslap Aura General 17 04-19-2007 09:07 PM
Can anyone explain this??? Gottofried S-Series Tech 19 08-13-2006 08:32 AM
can you explain this? S3aturnR S-Series Mods 13 07-08-2006 10:32 PM
Someone explain this to me mysweetgreenvue Vue General 3 07-30-2005 08:11 PM
Could someone explain this to me Whelan S-Series Mods 6 06-29-2001 09:19 AM
