Old 10-31-2017, 04:09 PM   #21
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Default Re: When buying a saturn s series what should you look for?
Originally Posted by alordofchaos View Post
Congrats on the new car, looking forward to hearing more.
yeah, for $900 it's not bad at all.
Some rust on rear 3rd door sill at bottom around bend (about 2"x3" spot) I might be able to cut it out and do something with it to prevent it from getting any worse. Rust has also started on the driver side subframe, but not too terrible especially compared to my '94 SL.
Anyone have any suggestion on what to do with the rust that has started on these cars? And maybe suggestion on what preventative maintenance I could perform on the areas that are prone for rust??
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 11-01-2017, 01:40 AM   #22
onlinebiker
onlinebiker is a jewel in the roughonlinebiker is a jewel in the roughonlinebiker is a jewel in the rough
The best thing to prevent or stop rust is a big oil leak soaking everything down...
My dad - is big on soaking the undercarriage, the bottom of doors, pretty much anything you don't want rusting with a concoction of motor oil, kerosene and STP..... He even drills access holes to get into spots that are normally inaccessible.
He applies it with a tree sprayer with the nozzle tip removed so it sprays in all directions.
He will do it on a hot day parked on a gravel driveway, then let it drip off all day.
Does it work???
He had never had a car rust out, and he generally keeps them ten years or more..
driveable
92 SC2
93 SC2
95 SC2
96 SC2
97 SL2
97 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
97 SL2 - cooked engine
98 SC2 - rusty frame. Donor engine for above SL2
Old 11-01-2017, 08:50 AM   #23
rgrafton
rgrafton's Avatar
2002 SC1
Does it work???
why Kerosene and STP in the mix?
Old 11-01-2017, 11:34 AM   #24
trottida
trottida's Avatar
Take a wire wheel to the existing rust and take off all the loose stuff, clean the area with acetone, paint it with POR-15 and spraypaint over top with your favorite rattle can to protect from UV light.
Current rides
:canada:
Add to trottida's Reputation
Old 11-01-2017, 05:23 PM   #25
onlinebiker
You're expecting stuff parents do to make sense??
Bwaaahahahahaha
He claims the STP makes it stickier and the kero thins it enough to spray.....
My theory is that pretty much any petroleum product is going to be better than nothing..
driveable
92 SC2
93 SC2
95 SC2
96 SC2
97 SL2
97 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-01-2017, 09:31 PM   #26
rgrafton
rgrafton's Avatar
2002 SC1
Bwaaahahahahaha
I figured that's why... since motor oil wouldn't squirt out of a bottle really well lol...
i'm looking to possibly do the following to all of the metal on the car --
1) Use a wire brush to remove as much surface rust as possible
2) Use a cleaner/degreaser to clean areas. Let dry.
3) Use POR-15 Metal Prep, let dry.
4) Use POR-15 Rust preventative paint, let dry for at least 24 hours.
5) Apply oil mixture of some kind on everything
Anyone have any feedback on this process? Anyone have any experience with the Metal Prep product from POR-15? Think it's worth it?
also see pictures of the rusting door sill... What should I do with this?
IMG- https://www.dropbox.com/s/4juyupe4t3ik9lr/IMG_6377.jpeg
IMG- https://www.dropbox.com/s/p2rtxtnb0e3dk5p/IMG_6378.jpeg
IMG- https://www.dropbox.com/s/45vye8qe7scvi2u/IMG_6380.jpeg
It appears that the area with the hole is only a thin sheet of metal going across which is why the rust ate it away and now there's a hole. The area to the right of that is multiple layers of metal and the top layer is gone and next layer is rusting away.
Old 11-03-2017, 12:13 AM   #27
rgrafton
rgrafton's Avatar
2002 SC1
As for the visible hole, should I fill with Body filler? I need to make sure everything is good to go when I get the inspection which I need by the end of the month.
Old 11-03-2017, 10:23 AM   #28
magician22773
magician22773 will become famous soon enough
1997 SL
Yikes! So glad I don't live in the Rustbelt!
If all you need is a cover up for an inspection, then sure, slap some filler in there and a little rattle can paint to hide it.
But in the long term, that is going to need real attention. Best way is obviously to cut it out, and weld in a new rust free patch. But with that much rust in the sill, I would be looking VERY close at all the other typical areas under the car, just to make sure you don't put a lot of time and effort into a car that could have serious rust problems where it really matters.
Since rust is really about the only thing that can actually kill a Saturn, in the future, I would consider looking for a car outside of the rustbelt, and traveling a little to get it. The couple hundred bucks spent on a cheap one way plane ticket will pay off in the end.
1994 SC2 Retired
1996 SL "FrankenSaturn"
1998 SL2 FrankenSaturn's Body Donor
2004 Vue "What was I thinking?"
2001 SL1 100k Mile Baby Blue Beauty
1999 SL2 Thank You Tiger!
Add to magician22773's Reputation
Rate the quality of this post and help magician22773 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magician22773 is offline   Reply With Quote
Old 11-04-2017, 08:10 PM   #29
rgrafton
rgrafton's Avatar
2002 SC1
the only reason there is a hole visible is because the metal at the bottom door sills is actually hollow with only a thin shell of metal. Opposed to the curved metal going upward toward the top of the car which is reinforced with multiple layers of metal. See image - https://www.dropbox.com/s/orheho32sy...78_2.jpeg?dl=0
The area I circled in green is reinforced with multiple layers of metal while everything to the left of that is simply 1 layer shell.
It actually wasn't that bad. I ground down the rust as much as possible. The first layer was the only layer rusted all the way through and the second layer was left pitted after grinding away the rust, but otherwise in decent shape.
what to look for when buying S-series 1996SL11.9L S-Series Tech 4 03-29-2012 09:37 PM
Talk me out of buying a used Saturn s series car jackthe S-Series General 43 01-26-2012 01:24 PM
Buying a Saturn S-Series? gunarpants S-Series General 45 07-17-2010 08:34 AM
My frustrations in buying a saturn S-series... Padge S-Series General 20 08-09-2006 03:42 PM
Thinking of buying a used S Series Saturn.... saturnowner2001 S-Series Mods 14 02-13-2006 12:32 PM
