Old 10-23-2017, 03:53 PM   #1
Chaotic wayz
Chaotic wayz is on a distinguished road
Default 1999 Saturn sc1 issues starting.
Hello, I searched the forum, but couldn't find the same problem.
1999 Sc1 new plugs &wires. Automatic.
Car will sometimes die while driving or just idling. Car will also randomly not start. It will crank, but not start. After trying to start it for anywhere from 5- 15 min it will start, and work fine until the next random occurrence. I was thinking cas, but figured I would ask here. Thank you in advance.
Add to Chaotic wayz's Reputation
Rate the quality of this post and help Chaotic wayz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chaotic wayz is offline   Reply With Quote
Old 10-23-2017, 05:00 PM   #2
Default Re: 1999 Saturn sc1 issues starting.
What's 'cas'? As a newbie, try the first sticky in this forum about the original coolant sensor failure and t-stat replacement for hard starting/flooding/rich running/high idling/xmission shift issues. If your idle is above 1k rpm, its probably the original coolant sensor (round nosed plastic). The flat nosed brass replacement fixes this problem permanently.
Old 10-23-2017, 07:30 PM   #3
billr
CAS is often used (on other cars) to indicate "Crank Angle Sensor", the CKP sensor, along with CMP if the system uses one.
Add to billr's Reputation
Saturn SL1 1999 Not Starting, nothing turn on - intermittent lanf S-Series Tech 2 07-09-2014 09:11 PM
1999 Saturn sc1 electrical/starting problem streetrodder51 S-Series Tech 2 05-17-2014 04:04 PM
1999 SC1 Hard Starting Issues streetrodder51 S-Series Tech 7 05-16-2014 11:05 AM
1999 Saturn SL2 not starting after turning car off frankreynolds S-Series General 1 06-04-2012 04:44 AM
Please Help 1999 SL Starting/Running Issues! gunghoe9 S-Series Tech 0 11-12-2006 05:03 PM
