Old 10-23-2017, 10:01 AM   #1
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
Default Will 1996 AC clutch fit 2002 AC compressor?
I know ac clutches may have different connectors but physically are they the same?
Will a 1996 ac clutch fit a 2002 compressor?
Thanks
Tom
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 10-23-2017, 11:48 AM   #2
toggenburg
toggenburg's Avatar
Default Re: Will 1996 AC clutch fit 2002 AC compressor?
I checked 2 sourcess, and both provide different part numbers for the AC clutch for those 2 years.
Old 10-23-2017, 06:36 PM   #3
Its anyone's guess whether or not parts swapping will work. Best case scenario are the two compressor are the exact same model with the exact same dimensions for ac fittings, wiring, and clutch parts. Even clutch parts change on the same compressor. Worse case scenario are two different models from the same manufacturer or not the same manufacturer. Worse case scenario at best may require trial and error fitting and checking dimensions for interchangeability. No one has specs for these dimensions unless having access to factory engineering drawings or rebuilders that may have inside info for parts interchangeability.
Old 10-23-2017, 08:32 PM   #4
Tommie
1996 SL1
2002 SL1
Thanks guys, I was hoping someone had tried this in the past...
Old 10-23-2017, 08:49 PM   #5
toggenburg
toggenburg's Avatar
Wait Tommie!
I found that partsgeek.com shows the same part number for both the 96 & 02!
2002
2002 Saturn SC2 A/C Clutch - Genuine W0133-1889779
1996
1996 Saturn SC2 A/C Clutch - Genuine W0133-1889779
Old 10-24-2017, 11:45 AM   #6
Tommie
1996 SL1
2002 SL1
Really? Thanks...I hope it is the same when I take it apart!!!! Has anyone out there done this for sure??
Old 10-24-2017, 12:20 PM   #7
Tommie
1996 SL1
2002 SL1
So apparently from checking out other websites with the part number that all the ac clutches will mount and just the plug should be different...can anyone else confirm this?
https://www.newegg.com/Product/Produ...0PE-003M-000N1
Old 10-24-2017, 12:54 PM   #8
Had to pick a '98 SC2 to get all _4_ clutch design options (numbered in same order top to bottom they showed up on the parts diagram page):
1)'91-'96 https://www.wholesalegmpartsonline.c.../19190320.html
2)'91-'95 (compressor has high temp sensor, not interchangeable) https://www.wholesalegmpartsonline.c.../21031318.html
3)'99-'02 https://www.wholesalegmpartsonline.c.../21031321.html
4)'98-'99 (requires 3rd design compressor with indent for clutch connector) https://www.wholesalegmpartsonline.c.../21031256.html
Guess '97's are S.O.L. if the A/C clutch goes bad lol
Old 10-24-2017, 02:39 PM   #9
Tommie
1996 SL1
2002 SL1
So will a 96 fit a 2002?
Old 10-24-2017, 03:03 PM   #10
toggenburg
toggenburg's Avatar
Got any Saturn junk yards around where you can locate a 96 & 02 and see?
Old 10-24-2017, 03:08 PM   #11
Tommie
1996 SL1
2002 SL1
I have a 96 in my hands but do not want to attempt swapping if it doesn't work...The mount looks identical but not sure if clearance is an issue with the 2002.
Old 10-24-2017, 03:28 PM   #12
Tommie
1996 SL1
2002 SL1
https://www.carid.com/genuine/a-c-cl...13037#features
Notes:
Clutch can only be used with 2nd Design Compressor, Which can be Identified by "High Temp" Sensor Being Eliminated and Electric Connector on a Pigtail. more details on - https://www.carid.com/genuine/a-c-cl...13037#features
I'm confused now.
Old 10-24-2017, 03:59 PM   #13
toggenburg
toggenburg's Avatar
Go and physically compare, OR just purchase NEW what you need for 2002.
Old 10-24-2017, 05:53 PM   #14
toggenburg
toggenburg's Avatar
You list both a 96 & an 02 under your signature bar; so is it safe to presume that you no longer have access to both for comparison's sake?
Old 10-25-2017, 07:11 AM   #15
Tommie
1996 SL1
2002 SL1
I do have both cars and a spare 96 ac compressor. I just didn't want to take apart the 2002 until I had the right parts but was hoping the 96 would do the trick. So it might work unless physically there is a clearance issue...the mounting holes and tab look identical.
Old 10-25-2017, 09:03 AM   #16
Based on your presumption of a faulty clutch or coil on your '02, may I ask what you did to verify this?
Old 10-25-2017, 10:08 AM   #17
4 designs of the clutch, 2 look identical and could be interchangeable but going by the official part numbers (which I posted before along with the years they interchange) they are not:
Most of the people in the past to figure this sort of thing out were happier to remove A/C all together and have increased performance from reduced weight (or more room for a turbocharger).
Old 10-25-2017, 01:06 PM   #18
Tommie
1996 SL1
2002 SL1
With AC on voltage is being applied to clutch plug but there is no engagement. Compressor turns.
Old 10-25-2017, 08:44 PM   #19
toggenburg
toggenburg's Avatar
Compressor turns by belt movement, but no clutch engagement?
Are you sure there is R134a in the system....y'all might be too low for the system to turn on?
And what is the ambient temperature up in Toronto when you are attempting to have the AC function? Your temps are dropping kinda low for the AC to work, no?
Old 10-25-2017, 10:27 PM   #20
Need to measure the clutch coil resistance. Remove power connector and measure resistance between power supply pin in clutch connector and the compressor body.
AC clutch and compressor halfey Ion Tech 4 07-13-2010 05:07 AM
1996 SL2 Compressor and Fan will not kick in Larry Horne S-Series Tech 16 02-23-2010 11:56 AM
A/C Compressor Clutch FrozenPilot S-Series General 13 06-11-2008 01:59 AM
Compressor Clutch erick295 S-Series Tech 7 01-05-2006 03:48 PM
WTB: 93 SC2 A/C Clutch or Compressor or Both TIMSPEED Classifieds 2 07-11-2002 07:25 PM
