Old 10-23-2017, 09:16 AM   #1
timl865
timl865 has a spectacular aura abouttiml865 has a spectacular aura abouttiml865 has a spectacular aura about
Default How does the Steering wheel come off?
I tried searching but all I kept finding was ion wheel removal. Is it the Same? I have a 2002 lw200. Thanks!
Add to timl865's Reputation
Rate the quality of this post and help timl865 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timl865 is offline   Reply With Quote
Old 10-24-2017, 12:50 AM   #2
pierrot
pierrot's Avatar
Default Re: How does the Steering wheel come off?
If you have no access to a repair manual of any kind send me a p/m with an email address. I will send you information.
278,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 10-24-2017, 11:28 PM   #3
timl865
Thanks I finally found the info I needed. Thanks
Old 10-25-2017, 10:06 AM   #4
pierrot
pierrot's Avatar
Great! Would you please share with the forum where you found the information? It could be of use to others in a similar situation.
Old 10-25-2017, 10:04 PM   #5
timl865
Nothing came up when I searched airbag or wheel removal. Once I did a search for clockspring removal a video was listed that detailed removing the airbag and wheel. Hope this helps
Old 10-26-2017, 08:23 PM   #6
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Releasing the spring clips that hold the airbag is very difficult. A flat blade screwdriver of a very specific length is required. The last time I did this I just cut the plastic cover on the back of the steering wheel at the 6 o'clock position and just pulled it off. This exposes the clips which can then be easily released. The cover just snaps back into place when you are done. You won't notice the cut. Don't forget to disable the airbag before you start at the yellow connector under the dash.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-15-2017, 09:29 PM   #7
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
For the air bag It says to rotate the screwdriver but I 've had more luck with rotating and pushing the screwdriver back and forth at the same time. And you gotta really bury the screwdriver first. I've taken the instrument panel right out to give me more room at times. After you hear those four clicks to release the bag, the steering wheel is ice cream. Loosen the nut and pull. don't take it off you'll whack yourself real bad when the wheel snaps loose.
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
Replacing steering wheel - how do I make sure coil behind steering wheel is ok? vikasevan S-Series Tech 2 12-29-2014 12:32 PM
Something in the steering snapped, steering wheel turns around and around, tires wont BullyCanadian Vue Tech 20 03-26-2014 11:23 AM
leather steering wheel question/steering wheel comment 2006 ion2 Ion General 4 04-29-2010 06:27 PM
2003 Vue Steering Wheel Tunk Noise When Turning Wheel kencat Vue General 6 03-05-2010 06:06 PM
rubbing noise steering wheel/steering column on 04 Vue ynotps Vue General 6 03-03-2005 07:59 PM
