Old 10-21-2017, 05:44 AM   #1
datlas
datlas is on a distinguished road
Default Radiator Flush?
True Confession Time:
Original owner 1998 SL. 160K miles.
I don't believe I have EVER had a radiator flush. I recently had the car in the shop and the mechanic said the fluid is dirty and suggested a flush. At this stage, will that do more harm than good? Worth doing?
Add to datlas's Reputation
Rate the quality of this post and help datlas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
datlas is offline   Reply With Quote
Old 10-21-2017, 06:30 AM   #2
Waiex191
Waiex191's Avatar
Default Re: Radiator Flush?
I had mine flushed and changed to Green stuff at 30K. Next time I touched it was at 204K. I'd say it is worth doing.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-21-2017, 04:56 PM   #3
dummo
dummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nicedummo is just really nice
dummo's Avatar
1997 SW2
Yes, flush it. And flush it again!
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 10-21-2017, 09:59 PM   #4
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
+1
Flush the system. You will get better heat transfer to the coolant, which will give you hotter heat inside. It should also heat up faster
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Old 10-23-2017, 10:38 AM   #5
No harm can come from a flush, done correctly. It's quite easy to do it yourself and that would be the best way.
If having a shop do it, see if they will allow you to bring your own antifreeze and distilled water. About a quart of water will remain in the heater core area and if they refill using a 50/50 premix, your coolant will be weak (less of an issue if you are in a hot part of the country, a concern if you get cold weather)
They should fill with full strength antifreeze, then top off with distilled (some shops just use tap water . . . any problems will not show up for many years/tens of thousands of miles, so no big deal to them)
Radiator Flush CreakyOldLady S-Series Tech 4 08-10-2015 01:38 PM
Radiator Flush or Radiator Drain ? whitesox S-Series General 5 06-09-2013 11:38 PM
new radiator, flush now or later????? nice186 S-Series Tech 11 02-08-2010 03:20 PM
Radiator Flush brownmota S-Series Tech 2 05-25-2007 12:44 PM
Radiator Flush SATURNER S-Series Tech 6 06-03-2005 01:48 PM
