Old 10-20-2017, 07:54 PM   #1
guitarjesus
guitarjesus is on a distinguished road
Default 2007 Vue 2.2 no brake lights, third brake light still works
Ok so both Of my main brake lights are out. The filaments are good, and the 3rd brake light still works. I read somewhere that the 3rd brake light possibly isn't connected to the brake light switch. Can anybody confirm this?
Also, besides the brake light switch, any culprits I should look for? Answers are much appreciated.
Add to guitarjesus's Reputation
Rate the quality of this post and help guitarjesus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guitarjesus is offline   Reply With Quote
Old 10-21-2017, 07:39 PM   #2
Default Re: 2007 Vue 2.2 no brake lights, third brake light still works
There are at least two things to check - brake fuse and brake switch. There may be two brake switches by the brake pedal - one for brakes, the other for cruise control. At sunset, parked with the rear backed up into a parking spot so you can see a reflection from a store window or garage door, you might be able to manually operate each brake switch to see which one turns on the third brake lights. This switch operates brake lights thru the body control module (not likely for a faulty bcm).
Third Brake Light: Only works when it is hot out? Slice57 Aura General 8 01-09-2016 09:33 AM
left and right brake lights don't work but centre high brake light works. microsat S-Series General 15 01-08-2014 10:44 PM
1998 SL - lower left & right brake lights out, center works gratefuldogs S-Series Tech 8 10-16-2010 11:35 AM
One Brake light works c cow Vue Tech 2 08-08-2010 08:37 AM
'95 SL1 Third Brake light works tail brake lights dont' DazMan S-Series Tech 3 03-10-2005 12:20 AM
