Old 10-20-2017, 12:41 PM   #1
Justgetmefixed
Justgetmefixed is on a distinguished road
2000 SL2
Default were did you come from,were did you go for that little hole
hey guys! so in need of a little help, was out last night went to 711 shut my car off got my stuff and came out, started my car (2000 sl2 dohc) and the idle was high got it home in one piece pulled the battery out thinking maybe the iac or the tps went all funky on me ,turns out it was my positive crankcase hose had popped off but i also noticed there was a hole on the passenger side of my intake manifold for another vacuum line but nothing in its place, i put my finger over the hole and can feel a vacuum being pulled the rpms dont go up or down the car just smooths out on idle ill post pics of it and maybe you guys can tell me if i should leave it or put a hose on and clamp it off ,thanks guys!
Add to Justgetmefixed's Reputation
Rate the quality of this post and help Justgetmefixed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Justgetmefixed is offline   Reply With Quote
Old 10-20-2017, 02:28 PM   #2
Default Re: were did you come from,were did you go for that little hole
If you do not have a secondary air injection system on the engine then there should be a cap on the vacuum port. If you have air injection then you should have the vacuum line like the one in your picture.
Add to ssicarman's Reputation
Old 10-20-2017, 02:40 PM   #3
Justgetmefixed
2000 SL2
how do i know if i have one or not? is it like a aftermarket add on?
The older the better I say
Sl2 saturn dohc, custom deck with over 260km still running strong
Old 10-20-2017, 03:26 PM   #4
Secondary air injection is an OEM emissions device. Your car probably came with it but it may have been removed by a previous owner. I think it was standard after 1999 on the S series.
You'll have a silver tube exiting the exhaust - look at your engine, it'll come out of the exhaust area and turn 90 degrees to the passenger side; goes into a disk-looking thing, connected to a bunch of other stuff and a big, black cylindrical plastic covered air pump
Pics of the silver tube here (I can't see pics so there may be pics of other things)
http://www.saturnfans.com/forums/sho...d.php?t=147661
This video covers troubleshooting the entire system. It will give you an idea of what parts this system has
https://www.youtube.com/watch?v=dIrmkxj6wJE
I came here for Cotton Eye Joe . . .
Old 10-20-2017, 03:37 PM   #5
Justgetmefixed
2000 SL2
awesome to hear! ill be getting some tubing and plug it off thanks for the help!
Oil in 3 and 4 plug hole storm_amoure S-Series Tech 6 09-21-2007 06:36 AM
bullet hole 944obscene S-Series General 23 08-04-2006 09:08 PM
Hole in oil pan :( replaceing or fix??????? jcurrieirocz S-Series General 14 04-08-2005 03:57 PM
Where would I Drill this hole? mike p S-Series General 9 01-17-2005 09:37 PM
hole through firewall jumpn Vue General 5 11-17-2004 12:15 PM
