Old 10-19-2017, 04:58 PM   #1
uluz2a6
uluz2a6 is a jewel in the roughuluz2a6 is a jewel in the roughuluz2a6 is a jewel in the rough
Default Anybody tried this?
Ran into a guy at local Pick-A-Part that claims he can remove a 2.2 Ecotec out of a 2005 Vue with a manual transmission through the top. Says just need to pull off the mounting bracket for front motor mount, belt tensioner, alternator, A/C compressor, and front cover. Says its tight but way easier than dropping out the sub-frame.
Just curious if anybody had attempted this bit of a shortcut.
Add to uluz2a6's Reputation
Rate the quality of this post and help uluz2a6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
uluz2a6 is offline   Reply With Quote
Old 10-24-2017, 08:17 PM   #2
Bfazona
Bfazona will become famous soon enough
Default Re: Anybody tried this?
My brother and I have used this method twice. Once to replace his engine and again to replace the clutch and timing chain in mine. Remove the hood and keep the ac connected, just zip tie it out of the way. Got to remove all motor mounts and the exhaust manifold too. Removing it gives you more room toward the firewall.
Add to Bfazona's Reputation
Rate the quality of this post and help Bfazona reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bfazona is offline   Reply With Quote
