Old 10-19-2017, 04:10 PM   #1
jswingchun
jswingchun is on a distinguished road
jswingchun's Avatar
1992 SL2
Default Speedometer/Odometer not working
I have a 92 SL2, manual transmission.
My speedometer and odometer are not working. Speedometer is at zero, odometer is not turning. All other gauges work.
I have read quite a bit on here about this, I know that the vehicle speed sensor is often the cause of this, but my cruise control is working and if I have read correctly that should rule out the VSS.
Am I right?
Where should I start?
Thanks!!
92 SL2 - 280k miles
Add to jswingchun's Reputation
Rate the quality of this post and help jswingchun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jswingchun is offline   Reply With Quote
Old 10-19-2017, 04:31 PM   #2
RobertGary1
Default Re: Speedometer/Odometer not working
Swap the cluster with one from a junk yard.
-Robert
RobertGary1 is online now   Reply With Quote
Old 10-21-2017, 01:02 PM   #3
stmcmurray76
stmcmurray76 is on a distinguished road
I have interest in this topic. I need to replace the guage cluster in my 92 Saturn SL1. Sounds easy enough, but when I search for it, the cluster is different than mine. I have seen a few photos of the cluster I need, and they are from 95 and 96,but it seems not all 95 and 96. I guess I just need to go walk through the junk yard and see if I can find a match. Any idea why there is no consistency with the use of this peticular cluster?
Add to stmcmurray76's Reputation
Rate the quality of this post and help stmcmurray76 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stmcmurray76 is offline   Reply With Quote
Old 10-21-2017, 03:04 PM   #4
SOHC should be compatible '91-'94. No idea where you're getting the idea that '95-'96 is what you need for a '92 but if it's a parts interchange...I wouldn't trust the paper it's written on anymore...lol
DOHC cluster's also got an oil pressure gauge for '91-'92, was removed in '93. The clusters are still plug & play swappable, but the oil pressure sender has to be swapped for a proper sensor and the extra wire run to the cluster.
Old 10-24-2017, 06:02 PM   #5
jswingchun
jswingchun's Avatar
1992 SL2
After that quick interlude...
In case anyone is interested in this thread later, I pulled my cluster and cleaned the pins on the connector and the traces where it connects to the cluster. Put it back together and now everything works again.
92 SL2 - 280k miles
93 SL1 Speedometer/odometer not working teamsl1 S-Series Tech 5 12-06-2007 08:56 PM
Speedometer/Odometer Not Working Tom64 S-Series Tech 12 11-27-2007 05:30 PM
Speedometer and odometer not working?! CBXweb S-Series Tech 1 11-11-2006 10:50 PM
Odometer/speedometer not working...VSS or fuse or something else? Hanshananigan S-Series General 3 07-26-2006 11:13 AM
speedometer working, odometer not? bryan_johnson S-Series Tech 3 05-15-2003 07:57 AM
