Old 10-19-2017, 03:57 PM   #1
jshadwick
jshadwick is on a distinguished road
Default Tach problem
I'm having a small problem with my 99 sw2 and can't seem to find any ino on it. Whenever it's cold outside my tach guage will climb all the way to red line and max itself out and stay there. Once the car is warmed up and I turn it off it goes down. Then restart and it's fine. Any help would be great. Thanks
Add to jshadwick's Reputation
Rate the quality of this post and help jshadwick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jshadwick is offline   Reply With Quote
Old 10-19-2017, 08:09 PM   #2
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default Re: Tach problem
Not sure, ever since it got colder out our 99 SL2 needle gets stuck vibrating at 0 for a few seconds then shoots up to where it normally is... Our 97 and my 94 do not do that. Maybe its just an issue with the instruments on 99's?
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-20-2017, 09:05 AM   #3
Are you saying that the engine runs at normal speed but the tach needle incorrectly shows high rpms, or that then engine itself runs at super high speed/rpms and the tach is correctly showing the high rpms?
Old 10-20-2017, 03:06 PM   #4
jshadwick
Sorry, I should have worded it better. Yes, the engine runs normal it's just the guage that seems to be acting up. Thanks
Odometer, tach, speedo, gas gauge problem! gene34 Introductions & Greetings 0 04-09-2014 10:17 PM
Speedo/ Tach light problem Warren Webb L-Series Tech 0 03-19-2011 11:27 PM
Tach problem and stalling sliderhd S-Series Tech 5 06-09-2008 06:27 AM
IonRedline Tach redline problem? amishland Ion General 26 08-31-2004 02:15 PM
tach. problem sc295 Miscellaneous Tech 1 12-11-2001 11:16 PM
