Old 10-19-2017, 01:35 PM   #1
seymourj98
seymourj98 is on a distinguished road
1994 SC2
Default Oil pump bearing alignment on crankshaft
Trying to reinstall the timing cover, but I can't seem to get the oil pump bearing to line up right with the crank to allow the crank to slip through the cover.
1994 Black and Gold Saturn SC2 156k
Add to seymourj98's Reputation
Rate the quality of this post and help seymourj98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
seymourj98 is offline   Reply With Quote
Old 10-19-2017, 01:58 PM   #2
Default Re: Oil pump bearing alignment on crankshaft
If you were changing the chain and kept the old sprockets, the bottom one can be reversed, stuck into the cover from the front, and used to hold the oil pump in place.
Otherwise, you might need to carefully use screwdrivers to get things in position and not bump anything while reinstalling. A bit of thick oil might help keep things in place but it won't be easy.
Old 10-19-2017, 08:44 PM   #3
seymourj98
1994 SC2
Used some assembly oil and a pick and managed to figure out how to align the pump, I did a few dry runs to make sure I could get it on before I ran the rtv. Thanks for the help.
Old 10-20-2017, 08:20 AM   #4
Glad you got'er done!
Thanks for following up. Good for future searchers to know whether something worked or not
Spun Rod Bearing - swap engine or crankshaft? iss407 S-Series Tech 13 04-10-2012 11:17 AM
2003 Vue 2.2 Crankshaft pilot bearing/bushing. davemanuel Vue Mods 0 03-19-2011 09:12 PM
Crankshaft Bearing Tie Plate Insert tool dcflh07 S-Series Tech 0 01-27-2011 07:44 PM
Alignment/Bearing? VueGuy168 Vue Tech 3 06-23-2009 03:30 PM
Finished bearing job-now alignment's off fleedermouse S-Series Tech 5 06-09-2008 10:04 AM
